- Thank you received: 1
ISR 1941 as a DHCP client on Gi0/0
13 years 4 months ago #37607
by talk2sp
BORN TO BE GREAT
c0de - 3
Replied by talk2sp on topic Re: ISR 1941 as a DHCP client on Gi0/0
Thanks a Million Chris. I will work on the leads you have provided. From all indications, it smells easily fixable.
Will post an update soon.
BORN TO BE GREAT
c0de - 3
13 years 4 months ago - 13 years 4 months ago #37609
by talk2sp
BORN TO BE GREAT
c0de - 3
@Chris.
I was just scrolling through an article on technet about DHCP server config and it specified that to deploy dhcp server on winserver2008, you must have a static ip address. Now this static ip address i assuming they are referring to the one from the ISP. Now in this case were the 3G usb Modem does not get a static ip from the provider. Will our solution and lead still be feasible. I am raising this because yesterday after i shared the 3G connection, it automatically gave an interface that i selected an IP of 192.168.0.1 but when i connected that interface directly to my notebook, it did not give my notebook an address. First i thought may be my config of DHCP was not accurate but I rechecked and will still recheck today.
Chris since the 3GUSB modem does not get a static IP address can it still serve us for what we are trying to achieve here?
If the connection was straight that is from the ISP modem (even if it's a dynamic ip), I will simply do; Router(config-if)#ip address dhcp but right now since it is usb, i have to use the server. And Looks like the server is not distributing DHCP addresses because the IP it is receiving is not a static IP.
Will be patiently and eagerly awaiting your comments Chris.
Thanks.
Thanks.
BORN TO BE GREAT
c0de - 3
Last edit: 13 years 4 months ago by talk2sp. Reason: Update
