Auto Switching
13 years 6 months ago #37422
by bkash
Auto Switching was created by bkash
hi,
i have 2 link connection in cisco swithches(C2960) with in 100Meter in LAN.The cisco switch are working in default vlan-1.
1-Link:- Fiber Connection
2.-Link:- UTP cat6 Connection.
so,i want to know,
1. which link is preferred first ?
2. and did we changes in any configuration cisco switched?
plz clear me....
so,i want to know,
plz clear me....
13 years 6 months ago #37424
Replied by Chris on topic Re: Auto Switching
Bkash,
When you have two links between switches, by default, one of the two will be blocked by the spanning tree protocol.
In your case, if both links are 1000Mbit, they will have the same path cost which means then that the one with the lowest MAC address (if my memory serves me well) will be placed in blocked mode.
Which ever the way, I'd highly suggest you ensure the fiber optic link is enabled and the UTP link is placed in blocked mode. You can easily configure this by lowering the STP cost of the fibre link.
For example, if GigabitEthernet 0/2 is the fiber link, enter the following commands to ensure its made the active link:
This will make the 'path cost' for that link much lower than that of the UTP, and STP will automatically start using this link.
On the other hand, you can also do something a bit smarter and 'combine' the two link into one, making it a nice 2Gigbit link between the two switches.
If one link goes down, e.g the fiber, you won't notice it as there won't be any down-time, and your speed will drop to 1Gigbit.
Here are the associated commands that need to be entered for both switches. Assume Gigabit0/1 & Gigabit0/2 are used on both switches:
Hope that helps!
Code:
interface GigabitEthernet0/2
switchport mode trunk
spanning-tree cost 5
Code:
interface Port-channel1
switchport
switchport trunk encapsulation dot1q
interface GigabitEthernet0/1
channel-protocol pagp
channel-group 1 mode auto
Hope that helps!
13 years 6 months ago #37437
by bkash
Replied by bkash on topic Re: Auto Switching
Hi Chris,
tx for prompt responce but my network are not in trunk mode all r access mode,i haven't enable to spanning tree. the both link r goes from gig to ether. so what is the possible for auto switching link.
13 years 6 months ago #37439
bkash,
If you haven't got any trunks, its not a problem, you can still use the above Port-Channel configuration, but leave out the 'switchport' commands.
On the other hand, if you have disabled STP, then if you don't create a port channel, that means you'll have loops in your network as each of the two links between your switches will start flooding your network with broadcast loops.
I hope this help you.
13 years 6 months ago #37448
by bkash
Hi Chris,
Im afraid of yur suggestion plz clear me again.."you'll have loops in your network as each of the two links between your switches will start flooding your network with broadcast loops"
Recentaly i hav problem 1 switch.
The UTP is the primary link in all switches but 1 swithc is hav taken fiber link and secondary is UTP but after shut down the fiber link is goes to UTP.also seen both link in cdp.
i could find why this swithc behavior diffrent others.
13 years 6 months ago #37451
by Nevins
Useful Threads
Replied by Nevins on topic Re: Auto Switching
Useful Threads
Time to create page: 0.235 seconds
