intervlan routing using layer 3 switch
13 years 8 months ago #37244
by payeh
intervlan routing using layer 3 switch was created by payeh
Hi all,
need help form experts here
I wanna ask about this condition (refer to the diagram)
is it possible to make intervlan routing between vlan 10 and 20 using level 3 switch (3650/3750)?
If possible then suggest me how to do that
Many thanks,
Payeh
Many thanks,
Payeh
13 years 8 months ago #37245
Replied by S0lo on topic Re: intervlan routing using layer 3 switch
Hi payeh, There is no link to the diagram. You can post here:
www.2shared.com
Yes you can do intervlan routing use both models of switches (3650 or 3750). The basic configuration is done using the ip routing command. Just issue this command, the layer 3 switch will start routing between your vlans.
If this doesn't answer your question, then we better see that diagram.
13 years 8 months ago #37246
by payeh
Replied by payeh on topic Re: intervlan routing using layer 3 switch
thanks Solo,
my problem now is solved, it seem i missed configuration for routing between vlan 20 and 10, just found the command how to configure it after the whole day googling
