*.iso
20 years 11 months ago #3632
by Neon
You can try and use a trial version of
Alcohol 120%
Very nice piece of software.
I assume you can still burn normal data discs?
20 years 11 months ago #3634
by indebluez
i have finally burnt it....not using nero, fireburner...or....
ii used the feature in win xp...i downloadd this component tt will add iso burner features...ffrom here
C:\Program Files\Alex Feinman\ISO Recorder\isorecorder.htm
its for win xp:) and it finally worked after 2 wks of askin ard and searchin the net...finally stumbled on somethin tt wks...no errors...
but i still dont understd why my nero refused to burn the iso...well maybe coz it jus sucks...hmm? no idea
20 years 11 months ago #3777
by sahirh
Well there mustve been some problem either with your nero or what you were doing.. was it writing normal cds fine ? What version of nero was it and was it registered ?
