Double Nat with Cisco asa 5505
14 years 4 months ago #35794 by MavsX
Hi-
I'm hoping i can get some help for an issue i'm having. I'm double natting with a verizon action tec router and my cisco asa 5505 behind that. I had everything working when i had a linksys router/wifi AP , but i pulled out the linksys and put the asa 5505 in it's place. I thought i had everything looking good, but, it doesn't work. When the outside interface is set to dhcp it works. but later on i want to add port forwarding to my network, so i want to get the outside interface of the cisco asa to 192.168.1.251/24
Here is my setup:
internet > fios action tec router > cisco asa 5505
i've got a dynamic IP from Verizon > the action tec router hands out IP's in the 192.168.1.2 -192.168.1.250 /24 subnet. the action tec is 192.168.1.1
the asa outside interface is 192.168.1.X/24 (it's getting it via dhcp from the actiontec) and the inside interfaces are 10.1.1.2-10.1.1.26. Mangement interface is 10.1.1.1
Everything is working fine, but, when i change the cisco outside interface to a static IP of 192.168.1.251/24 i can't get out onto the internet. If i set the outside interface back to get an IP from the action tec, the interface comes up and i'm fine on the net.
ciscoasa> en
Password: ***********
ciscoasa# show run
: Saved
ASA Version 7.2(4)
hostname ciscoasa
enable password oUptWweif9uVqAXo encrypted
passwd oUptWweif9uVqAXo encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 10.1.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan3
shutdown
no forward interface Vlan1
nameif dmz
security-level 50
no ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
timeout xlate 3:00:00
aaa authentication ssh console LOCAL
http server enable
http 10.1.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh 10.1.1.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcp-client client-id interface outside
dhcpd auto_config outside
dhcpd address 10.1.1.2-10.1.1.26 inside
dhcpd dns x.252.0.x x.242.0.x interface inside
dhcpd enable inside
username admin password 4F5RVIJxqcaUyNKc encrypted privilege 15
class-map inspection_default
parameters
message-length maximum 512
message-length maximum client auto
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
prompt hostname context
Cryptochecksum:e69bef80afbc3dd75c5fdc88772f3127
: end
ciscoasa#
14 years 4 months ago #35802 by MavsX
i figured it out. Since the command "ip address dhcp setroute" is setting the default route based on my dhcp ip address, once i set it too a static ip, the outside interface didn't know what to do. So i set a default route of route outside 0.0.0.0 0.0.0.0 192.168.1.1 i also waited for the action tec router to let the arp time out, and i was back in business...
