Can connect but not access LAN
14 years 6 months ago #35560 by matoposb0y
Hi there, I am having a problem accessing my LAN through the VPN. I can connect and login but I have no access. Here is my config, can you see anything obviously wrong?
ASA Version 8.2(1)
hostname FaDasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
name-server 192.168.1.1
access-list outside_access_in extended permit tcp any interface outside eq 65100
access-list FDvpn_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 209.165.201.0 255.255.255.240
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool RemoteClientPool 209.165.201.1-209.165.201.15
no asdm history enable
arp timeout 14400
global (outside) 1 interface
static (inside,outside) tcp interface 65100 192.168.1.6 65100 netmask 255.255.25
5.255
timeout xlate 3:00:00
timeout tcp-proxy-reassembly 0:01:00
http server enable
no snmp-server location
no snmp-server contact
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128
-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256
-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd enable inside
threat-detection basic-threat
webvpn
group-policy FDvpn internal
group-policy FDvpn attributes
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value FDvpn_splitTunnelAcl
username bob1 password rmLvvHLUthe9ahFo encrypted privilege 0
username bob1 attributes
vpn-group-policy FDvpn
username bob2 password eKwzKURFROhs60Y8 encrypted privilege 15
username bob3 password RYnHb7kyyB4/dldm encrypted privilege 0
username bob3 attributes
username bob4 password NGzhly1AoazPfSSa encrypted privilege 0
username bob4 attributes
username bob5 password jeBozWF5W3XCnmzZ encrypted privilege 0
username bob5 attributes
vpn-group-policy FaDvpn
tunnel-group FaDvpn type remote-access
tunnel-group FaDvpn general-attributes
address-pool RemoteClientPool
default-group-policy FaDvpn
tunnel-group FaDvpn ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:eb64f5a93211bc90fdb1fe147161343a
: end
14 years 6 months ago #35617 by Chris
I can't seem to find anything wrong with your configuration, however, try the following:
1) can you verify in your Cisco VPN client you have access to your local network when connecting to the VPN ? Check the Statistics/Routes and ensure the 192.168.1.0 network is there
2) Can you try replacing :
with
access-list FDvpn_splitTunnelAcl extended permit ip 192.168.1.0 255.255.255.0 192.168.1.0 255.255.255.0
Good luck!
