network printer not displaying default IP
14 years 8 months ago #35039 by sose
I remove an HP 2055 laserjet network printer from the pack and try to print its default IP from the button , the net config page printed without the IP . why ?
14 years 8 months ago #35049 by Arani
Replied by Arani on topic HP Printer
Hi Sose
Was the printer connected to any LAN while you tried that function. Sometimes the printer won't print any IP address if the network card does not detect a LAN connection.
Try it with the LAN cable plugged in and see if that makes a difference
14 years 8 months ago #35055 by S0lo
If this is a new printer (since you said unpacked), It could also have been configured (by default) to get an IP via DHCP. So as Arani, mentioned if the LAN cable is unplugged or you don't have a DHCP server (usually ISP router) connected to the same subnet, then it won't have an IP.
14 years 8 months ago #35095 by sose
the printer was configured to get IP authomatically , when I changed it to manual from the display button it worked.
thanks all
