election of DR and BDR in OSPF
16 years 6 months ago #33871
by wakatana
Replied by wakatana on topic Re: election of DR and BDR in OSPF
Hi, I am now testing election of BR and BDR on "real physical hardware".
So if you have loopback with smaller IP value than physical, always loopback is choosen for router ID (therfore DR/BDR).
On packet tracer it is according to value of IP not according to physical or loopback.
Also cisco curiculums refers to first option (loopback first, largness IP second)
Have you tested it on PT or on real hardware ?
PS: packet tracer did not recognize command
router# clear ip ospf process
therfore router reload
16 years 6 months ago #33880
by krik
Christophe Lemaire
www.exp-networks.be/blog/
Replied by krik on topic Re: election of DR and BDR in OSPF
I've never used PT, I've tested this on real hardware and on dynamips.
Now, in real networks, it is a very good and common practice to set the router ID manually. That way, it never change whatever happen to all the router interfaces.
Yes. And if you have several loopbacks, the one with the highest IP is choosen.So if you have loopback with smaller IP value than physical, always loopback is choosen for router ID (therfore DR/BDR).
According to me it is the same...Also cisco curiculums refers to first option (loopback first, largness IP second)
Christophe Lemaire
16 years 6 months ago #33886
by wakatana
So in conclusion:
TRUE ACCORDING PREVIOUS POSTS:
Priority is the first attribute which is held in election (0 did not elect, 1 default, higher better, maximum 255)
Second attribute (if priorities are equal) is router ID which can be affected by loopback or router id.
If neither loopback or router ID is set then RID is highest IP of physical interface.
If loopback is set (also with smaller IP than real interface) then RID is IP of loopback (if there are more loopback, the highest is choosen)
PT did not elect according loopback/physical but JUST according largeness of IP
AND WHAT IF ? FOR TOTALY CLEAR:
If there are RID set by Router(config-router)# router-id value (which can be smaller than physical highest IP) the RID is the router-id (Not physical IP)
Also If there are RID set by Router(config-router)# router-id value and there is also loopback (both can be smaller ip than physical) then the router-id is set
PS is there any online dynampis lab ? or something like that ? My PC is too slow to run GNS3 simulator.
Thank you
Thank you
- CCIE-Aspirant
16 years 5 months ago #34068
by CCIE-Aspirant
CCIE Service Provider Aspirant
Replied by CCIE-Aspirant on topic PT Does Support Lookback Router ID
Although PT does not support "clear ip ospf process" command, I did create a loopback int and power cycle the router. After it came up, I checked, router ID was the loopback address was the loopback address.
However, again, PT does not support "router-id" command. But It does support loopback add.
- ToxicAvenger
16 years 2 months ago #35015
by ToxicAvenger
the router with the highest OSPF priority becomes DR. <ranges from 1 thru 255>. Priority 0 routers never become DR.
The default priority for cisco routers is 1...so next comes router ID
the router with highest router ID becomes DR. The router picks/ prefers the highest configured loopback as its router ID. If no loopbacks r present than the router picks the highest physical interface as its router ID UNLESS 1 IS CONFIGURED with the router-id command.
<the router ID is NOT an ip address...just a 32 bit #>
Replied by ToxicAvenger on topic Re: election of DR and BDR in OSPF
<i did not bother looking at the topology but>Hi all, I am trying to understand OSPF and I have
As far as I know DR is the router with has highest IP address of loopback, if no loopback is set then the router which has highest (physical interface) IP address is the DR.
Time to create page: 0.104 seconds
