ASA 5505 and Linksys WRT610N ver2
- matoposb0y
- Junior Member
15 years 1 month ago #33761
by matoposb0y
ASA 5505 and Linksys WRT610N ver2 was created by matoposb0y
Hello everyone, I am a newbie and I am having a problem setting up a network and would appreciate any help that you may be able to offer.
I initially set up my broadband connection into the asa ethernet0/0 and my router to ethernet0/1. All computers connect to the router then the asa then the internet. It was all working fine when I decided to set up vpn and it all fell down and now nothing works, not even the internet. I have disconnected the asa and now have the internet go directly to the router which works fine. I have reloaded the default configuration on the asa via the command propmt using the tutorial from this site and it still wont work.
This is the first error I got:
myasa(config-if)# ip address dhcp setroute
ERROR: Failed to apply IP address to interface Vlan2, as the network overlaps with interface Vlan1. Two interfaces cannot be in the same subnet.
My linksys router has an ip addy of 192.168.1.1 and so does my asa, could this be the problem? I changed the linksys to 192.168.1.2 but it did not help.
I also tried to configure the asa with a static ip address, but that did not work either.
Does any body have any ideas on how i could set this up, or what I am doing wrong? Any help or reference to relevant literature would be greatly appreciated.
Thanking you in advance - Matoposboy
15 years 1 month ago #33797
by sys-halt
Replied by sys-halt on topic Re: ASA 5505 and Linksys WRT610N ver2
hey matoposb0y, normally Routers are thrown at the Perimeter of your Network to route, we usually connect the Internet Connection to the Router to provide the routing and we put the firewall behind our router to implement our rules for filtering.
of course if you reset your ASA it will not work properly until you reconfigure it from scratch.
I am not aware of your configuration on the ASA but it sound from the Error Message that you implemented two VLANs and you are trying to assigning them Addresses from the same IP Subnet. try using different IP Address scheme on one of the VLANs you are trying to create.
good luck,
good luck,
- matoposb0y
- Junior Member
14 years 9 months ago #34977
by matoposb0y
Replied by matoposb0y on topic Re: ASA 5505 and Linksys WRT610N ver2
Thanks for your replies. Please can someone answer the following questions which I am very confused about:
Question 1: When setting up vlan 2 :
ExampleASA(config)# interface vlan 2
ExampleASA(config-if)# ip address 212.115.192.193 255.255.255.248
ExampleASA(config-if)# nameif outside
INFO: Security level for "outside" set to 0 by default.
ExampleASA(config-if)# exit
ExampleASA(config)# route outside 0.0.0.0 0.0.0.0 212.115.192.192
Must the IP address be the next hop? My router ip address is 192.168.0.1 - so is this what I should use?
The route outside - what are the three parts of it? If I have a router with ip address 192.168.0.1 what ip address should I be using for route outside? are the three parts of route outside the hops? so should I have route ip and outside ip?
Question 2:
With global (outside) 10 interface and nat (inside) 10 192.168.1.0 255.255.255.0 does it matter if you use the number 10 or the number 1? Can you use any number? NAT inside should that be done by my firewall or my router, i.e. should the ip address be the router or firewall?
Question 2:
- matoposb0y
- Junior Member
14 years 9 months ago #34979
by matoposb0y
Here is my config:
ASA Version 8.2(1)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 192.168.0.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.168.1.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 192.168.0.1 1
timeout xlate 3:00:00
timeout tcp-proxy-reassembly 0:01:00
http server enable
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd enable inside
threat-detection basic-threat
webvpn
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect dns preset_dns_map
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
prompt hostname context
ASA Version 8.2(1)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
webvpn
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
- matoposb0y
- Junior Member
14 years 9 months ago #34984
by matoposb0y
I FIXED IT! WHOOOHOOO!
Now I need to know how to access the printer which is behind the firewall from a computer who connects wirelessly to the router then the firewall and then the printer - any ideas?
