Cisco DHCP Server - Problem & Answer
16 years 3 weeks ago #33809 by apit
S0lo,
Do i need to enable ip dhcp binding before activate IP Source Guard feature?
With IP Source Guard feature enable, what will happen to fix ip devices? Refer to the documentation :
The port ACL allows only IP traffic with a source IP address in the IP source binding table and denies all other traffic
16 years 2 weeks ago #33816 by S0lo
You only need static DHCP binding to let static IP addresses (for your servers) work. And this should answer your second question ;)
Here is how to do it. First you have to Enable DHCP snooping and enable it on your VLAN(s):
[code:1]ip dhcp snooping
ip dhcp snooping vlan 1
By default, all interfaces are Untrusted. So no need to touch that unless you want some trusted interfaces. Next step is to configure which interface(s) you want to use IP Source Guard on. Say Fa0/2:
[code:1]interface FastEthernet0/2
ip verify source[/code:1]
Now make sure that the host(s) connected to Fa0/2 renew their leased IP. You can do this by ipconfig /renew on a Windows console. You should notice now that when you set a static IP (that has not been leased) on a PC, the PC will not be able to connect to any thing.
You can show the DHCP snooping bindings using the sh ip dhcp snooping binding command.
Now, for your servers or hosts that you need manually configured static IPs, you need to manually add a binding for each one. Like this:
[code:1]ip source binding AAAA.BBBB.CCCC vlan 1 192.168.0.6 interface Fa0/2 [/code:1]
Replace AAAA.BBBB.CCCC with the MAC address of the server/host and 192.168.0.6 with it's static IP.
Finally, notice here that I used only IP filtering in the above, you can use both IP and MAC filtering by issuing ip verify source port-security above, but I didn't try that yet. This can be useful to prevent IP conflicts if a user sets his static IP to be the same as one IP that is already leased by DHCP to another host.
Hope it works for you.
16 years 1 week ago #33916 by apit
thanks s0l0..i will try it..
One more thing, when using "sh ip dhcp binding" command, this is output :
172.16.40.118 0100.1f29.957d.c4 Infinite Automatic
172.16.40.119 0004.0d01.f987 Infinite Automatic
172.16.40.121 0152.4153.2000.2655. Infinite Automatic
11e3.1800.0001.0000.
00
172.16.40.122 0152.4153.2000.2655. Infinite Automatic
11e3.1800.0002.0000.
00
Some ip got 2 MAC address. Why is it happen?
Time to create page: 0.100 seconds
