patch panel help
15 years 2 months ago #33637 by mawj
patch panel help was created by mawj
I don't have any idea about patch panel
any help in introducing the need of patch panel
why do we need it?
how do we use it?
15 years 2 months ago #33641 by TheBishop
Replied by TheBishop on topic Re: patch panel help
A patch panel brings the cables from all the individual network outlets in the building or area together in one place. Each individual outlet will be cabled back to a socket on the patch panel and usually identified there by a number or some other code. Short cables, known as pach cables or patch leads, are then used to connect the outlets as required into the network switches. Using a patch panel in this way makes the network very flexible as any given outlet can be reconnected to something else whenever required simply by moving its patch lead.
Does that help?
