ASA 5505 VPN problem
15 years 2 months ago #33635 by morto
ASA 5505 VPN problem was created by morto
Hi!
Im trying to setup a remote VPN connection and follow a guide i found to get it going.
But i get error 789 on the windows client.
And this error on the asa:
7|Feb 11 2010|17:32:04|713236|||||IP = 84.55.98.85, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 124
7|Feb 11 2010|17:32:04|715046|||||IP = 84.55.98.85, constructing Fragmentation VID + extended capabilities payload
7|Feb 11 2010|17:32:04|715046|||||IP = 84.55.98.85, constructing NAT-Traversal VID ver 02 payload
7|Feb 11 2010|17:32:04|715046|||||IP = 84.55.98.85, constructing ISAKMP SA payload
7|Feb 11 2010|17:32:04|715028|||||IP = 84.55.98.85, IKE SA Proposal # 1, Transform # 5 acceptable Matches global IKE entry # 4
5|Feb 11 2010|17:32:04|713257|||||Phase 1 failure: Mismatched attribute types for class Group Description: Rcv'd: Unknown Cfg'd: Group 2
7|Feb 11 2010|17:32:04|715047|||||IP = 84.55.98.85, processing IKE SA payload
7|Feb 11 2010|17:32:04|715047|||||IP = 84.55.98.85, processing VID payload
7|Feb 11 2010|17:32:04|715049|||||IP = 84.55.98.85, Received Fragmentation VID
7|Feb 11 2010|17:32:04|715049|||||IP = 84.55.98.85, Received NAT-Traversal ver 02 VID
7|Feb 11 2010|17:32:04|715049|||||IP = 84.55.98.85, Received NAT-Traversal RFC VID
7|Feb 11 2010|17:32:04|713906|||||IP = 84.55.98.85, Oakley proposal is acceptable
7|Feb 11 2010|17:32:04|715047|||||IP = 84.55.98.85, processing SA payload
7|Feb 11 2010|17:32:04|713236|||||IP = 84.55.98.85, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 384
7|Feb 11 2010|17:32:04|713906|||||Ignoring msg to mark SA with dsID 208896 dead because SA deleted
4|Feb 11 2010|17:32:04|113019|||||Group = DefaultRAGroup, Username = , IP = 84.55.98.85, Session disconnected. Session Type: IKE, Duration: 0h:00m:00s, Bytes xmt: 0, Bytes rcv: 0, Reason: Phase 2 Mismatch
5|Feb 11 2010|17:32:04|713259|||||Group = DefaultRAGroup, IP = 84.55.98.85, Session is being torn down. Reason: Phase 2 Mismatch
7|Feb 11 2010|17:32:04|713236|||||IP = 84.55.98.85, IKE_DECODE SENDING Message (msgid=80c163c7) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 80
7|Feb 11 2010|17:32:04|715046|||||Group = DefaultRAGroup, IP = 84.55.98.85, constructing qm hash payload
7|Feb 11 2010|17:32:04|715046|||||Group = DefaultRAGroup, IP = 84.55.98.85, constructing IKE delete payload
7|Feb 11 2010|17:32:04|715046|||||Group = DefaultRAGroup, IP = 84.55.98.85, constructing blank hash payload
7|Feb 11 2010|17:32:04|713906|||||Group = DefaultRAGroup, IP = 84.55.98.85, sending delete/delete with reason message
7|Feb 11 2010|17:32:04|713906|||||Group = DefaultRAGroup, IP = 84.55.98.85, IKE SA MM:f6af908e terminating: flags 0x01000002, refcnt 0, tuncnt 0
7|Feb 11 2010|17:32:04|713906|||||Group = DefaultRAGroup, IP = 84.55.98.85, IKE SA MM:f6af908e rcv'd Terminate: state MM_ACTIVE flags 0x00000042, refcnt 1, tuncnt 0
3|Feb 11 2010|17:32:04|713902|||||Group = DefaultRAGroup, IP = 84.55.98.85, Removing peer from correlator table failed, no match!
7|Feb 11 2010|17:32:04|715065|||||Group = DefaultRAGroup, IP = 84.55.98.85, IKE QM Responder FSM error history (struct &0xd8818690) <state>, <event>: QM_DONE, EV_ERROR-->QM_BLD_MSG2, EV_NEGO_SA-->QM_BLD_MSG2, EV_IS_REKEY-->QM_BLD_MSG2, EV_CONFIRM_SA-->QM_BLD_MSG2, EV_PROC_MSG-->QM_BLD_MSG2, EV_HASH_OK-->QM_BLD_MSG2, NullEvent-->QM_BLD_MSG2, EV_COMP_HASH
3|Feb 11 2010|17:32:04|713902|||||Group = DefaultRAGroup, IP = 84.55.98.85, QM FSM error (P2 struct &0xd8818690, mess id 0x1)!
7|Feb 11 2010|17:32:04|713236|||||IP = 84.55.98.85, IKE_DECODE SENDING Message (msgid=4b3f2583) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 84
7|Feb 11 2010|17:32:04|713906|||||Group = DefaultRAGroup, IP = 84.55.98.85, constructing ipsec notify payload for msg id 1
7|Feb 11 2010|17:32:04|713906|||||Group = DefaultRAGroup, IP = 84.55.98.85, sending notify message
5|Feb 11 2010|17:32:04|713904|||||Group = DefaultRAGroup, IP = 84.55.98.85, All IPSec SA proposals found unacceptable!
5|Feb 11 2010|17:32:04|713257|||||Phase 2 failure: Mismatched attribute types for class Encapsulation Mode: Rcv'd: UDP Transport Cfg'd: UDP Tunnel(NAT-T)
7|Feb 11 2010|17:32:04|715047|||||Group = DefaultRAGroup, IP = 84.55.98.85, processing IPSec SA payload
7|Feb 11 2010|17:32:04|713066|||||Group = DefaultRAGroup, IP = 84.55.98.85, IKE Remote Peer configured for crypto map: dyno
7|Feb 11 2010|17:32:04|715059|||||Group = DefaultRAGroup, IP = 84.55.98.85, Selecting only UDP-Encapsulated-Tunnel and UDP-Encapsulated-Transport modes defined by NAT-Traversal
7|Feb 11 2010|17:32:04|713906|||||Group = DefaultRAGroup, IP = 84.55.98.85, QM IsRekeyed old sa not found by addr
7|Feb 11 2010|17:32:04|715047|||||Group = DefaultRAGroup, IP = 84.55.98.85, processing NAT-Original-Address payload
7|Feb 11 2010|17:32:04|713906|||||Group = DefaultRAGroup, IP = 84.55.98.85, L2TP/IPSec session detected.
7|Feb 11 2010|17:32:04|713024|||||Group = DefaultRAGroup, IP = 84.55.98.85, Received local Proxy Host data in ID Payload: Address 195.7.78.182, Protocol 17, Port 1701
7|Feb 11 2010|17:32:04|714011|||||Group = DefaultRAGroup, IP = 84.55.98.85, ID_IPV4_ADDR ID received
7|Feb 11 2010|17:32:04|715047|||||Group = DefaultRAGroup, IP = 84.55.98.85, processing ID payload
7|Feb 11 2010|17:32:04|713025|||||Group = DefaultRAGroup, IP = 84.55.98.85, Received remote Proxy Host data in ID Payload: Address 192.168.0.199, Protocol 17, Port 1701
7|Feb 11 2010|17:32:04|715047|||||Group = DefaultRAGroup, IP = 84.55.98.85, processing nonce payload
7|Feb 11 2010|17:32:04|715047|||||Group = DefaultRAGroup, IP = 84.55.98.85, processing SA payload
7|Feb 11 2010|17:32:04|715047|||||Group = DefaultRAGroup, IP = 84.55.98.85, processing hash payload
7|Feb 11 2010|17:32:04|713236|||||IP = 84.55.98.85, IKE_DECODE RECEIVED Message (msgid=1) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + ID (5) + ID (5) + NAT-OA (131) + NONE (0) total length : 312
7|Feb 11 2010|17:32:04|714003|||||IP = 84.55.98.85, IKE Responder starting QM: msg id = 00000001
7|Feb 11 2010|17:32:04|715080|||||Group = DefaultRAGroup, IP = 84.55.98.85, Starting P1 rekey timer: 21600 seconds.
3|Feb 11 2010|17:32:04|713122|||||IP = 84.55.98.85, Keep-alives configured on but peer does not support keep-alives (type = None)
7|Feb 11 2010|17:32:04|713121|||||IP = 84.55.98.85, Keep-alive type for this connection: None
5|Feb 11 2010|17:32:04|713119|||||Group = DefaultRAGroup, IP = 84.55.98.85, PHASE 1 COMPLETED
6|Feb 11 2010|17:32:04|113009|||||AAA retrieved default group policy (DfltGrpPolicy) for user = DefaultRAGroup
7|Feb 11 2010|17:32:04|713236|||||IP = 84.55.98.85, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + VENDOR (13) + NONE (0) total length : 84
7|Feb 11 2010|17:32:04|715046|||||Group = DefaultRAGroup, IP = 84.55.98.85, constructing dpd vid payload
7|Feb 11 2010|17:32:04|715076|||||Group = DefaultRAGroup, IP = 84.55.98.85, Computing hash for ISAKMP
7|Feb 11 2010|17:32:04|715046|||||Group = DefaultRAGroup, IP = 84.55.98.85, constructing hash payload
7|Feb 11 2010|17:32:04|715046|||||Group = DefaultRAGroup, IP = 84.55.98.85, constructing ID payload
7|Feb 11 2010|17:32:04|713906|||||IP = 84.55.98.85, Connection landed on tunnel_group DefaultRAGroup
6|Feb 11 2010|17:32:04|713172|||||Group = DefaultRAGroup, IP = 84.55.98.85, Automatic NAT Detection Status: Remote end IS behind a NAT device This end is NOT behind a NAT device
7|Feb 11 2010|17:32:04|713236|||||IP = 84.55.98.85, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + NONE (0) total length : 64
6|Feb 11 2010|17:32:04|302015|84.55.98.85|4500|195.7.78.182|4500|Built inbound UDP connection 7325340 for outside:84.55.98.85/4500 (84.55.98.85/4500) to identity:195.7.78.182/4500 (195.7.78.182/4500)
7|Feb 11 2010|17:32:04|713236|||||IP = 84.55.98.85, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (130) + NAT-D (130) + NONE (0) total length : 304
7|Feb 11 2010|17:32:04|713906|||||Group = DefaultRAGroup, IP = 84.55.98.85, Generating keys for Responder...
7|Feb 11 2010|17:32:04|713906|||||IP = 84.55.98.85, computing NAT Discovery hash
7|Feb 11 2010|17:32:04|715046|||||IP = 84.55.98.85, constructing NAT-Discovery payload
7|Feb 11 2010|17:32:04|715048|||||IP = 84.55.98.85, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
7|Feb 11 2010|17:32:04|715046|||||IP = 84.55.98.85, constructing VID payload
7|Feb 11 2010|17:32:04|715038|||||IP = 84.55.98.85, Constructing ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
7|Feb 11 2010|17:32:04|715048|||||IP = 84.55.98.85, Send IOS VID
7|Feb 11 2010|17:32:04|715046|||||IP = 84.55.98.85, constructing xauth V6 VID payload
The ASA config looks like this:
: Saved
ASA Version 8.2(1)11
hostname ciscoasa
enable password iExlrVGCYde6N5s4 encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 195.7.78.* 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa821-11-k8.bin
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 195.7.64.3
name-server 195.7.64.131
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service visualSVN tcp-udp
description SVN
port-object eq 8443
access-list inside_acl extended permit ip any any
access-list outside-acl extended permit tcp any host 195.7.78.* eq 8443
access-list outside-acl extended permit tcp any host 195.7.78.* eq https
access-list 110 extended permit tcp any host 195.7.78.192 eq 8443
access-list outside_access_in extended permit tcp any eq https interface outside eq https
access-list VPN_SplitTunnel_ACL standard permit 10.0.0.0 255.255.255.0
access-list NoNAT_ACL extended permit ip 10.0.0.0 255.255.255.0 192.168.253.0 255.255.255.0
pager lines 24
logging enable
logging list test level debugging
logging asdm-buffer-size 512
logging asdm test
logging debug-trace
mtu inside 1500
mtu outside 1500
ip local pool cisco 10.10.10.1-10.10.10.100 mask 255.255.255.0
ip local pool VPNpool 192.168.253.1-192.168.253.250 mask 255.255.255.255
asdm image disk0:/asdm-623.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
static (inside,outside) tcp interface 8443 192.168.0.200 8443 netmask 255.255.255.255
static (inside,outside) tcp interface https 192.168.0.200 https netmask 255.255.255.255
access-group outside-acl in interface outside
route outside 0.0.0.0 0.0.0.0 195.7.78.2 1
timeout xlate 3:00:00
timeout tcp-proxy-reassembly 0:01:00
http server enable
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
crypto ipsec transform-set IPsec-Windows esp-3des esp-sha-hmac
crypto ipsec transform-set IPsec_iPhone esp-3des esp-md5-hmac
crypto dynamic-map dyno 20 set transform-set IPsec_iPhone
crypto map IPsec_map 20 ipsec-isakmp dynamic dyno
crypto map IPsec_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 20
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 300
telnet timeout 5
ssh 192.168.0.0 255.255.255.0 inside
ssh timeout 20
console timeout 0
l2tp tunnel hello 100
dhcpd auto_config outside
dhcpd address 192.168.0.5-192.168.0.132 inside
dhcpd dns 195.7.*.* 195.7.*.* interface inside
dhcpd enable inside
no threat-detection basic-threat
no threat-detection statistics access-list
webvpn
group-policy DfltGrpPolicy attributes
dns-server value 10.0.0.2
vpn-tunnel-protocol IPSec l2tp-ipsec
ipsec-udp enable
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPN_SplitTunnel_ACL
default-domain value dev.ss.local
split-dns value dev.ss.local
intercept-dhcp enable
tunnel-group DefaultRAGroup general-attributes
address-pool VPNpool
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
tunnel-group DefaultRAGroup ppp-attributes
no authentication chap
authentication ms-chap-v2
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
prompt hostname context
Cryptochecksum:76c9082e9d4734ce61fb7bd465227624
: end
Someone have any ideas?
Regards
Oscar
15 years 2 months ago #33671 by krik
Replied by krik on topic Re: ASA 5505 VPN problem
encryption 3des
hash md5
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
It seems your windows device is not configured to use DH group 2 in phase 1 while the ASA is for all its isakmp policies. You should try to activate it under windows or create a new policy without group 2 on the ASA (less secured)
Christophe Lemaire
www.exp-networks.be/blog/
15 years 2 months ago #33689 by morto
Replied by morto on topic Re: ASA 5505 VPN problem
How do i set what dh group in windows? Cant really find that.
Or how do i set it wothout group 2 in the ASA?
