Remote Management of Cisco router
15 years 2 months ago #33550 by ZiPPy
I'm a little stump why a particular option on a Cisco Wireless router w/ VPN has remote management grayed out. I have another on the other side with the option also disabled, but the port has been changed to 9191. The default is 8080. Why would this option be grayed out? Is there another setting that has to be changed prior to changing the port?
The manual states: Enable Remote Management and enter 8080 in the Port field. Please note that you cannot
enter any other value if you want to use the VPN Wizard. Also, make sure that HTTPS has
been selected.
But I haven't used nor plan to use the VPN wizard. Am I missing something here?
ZiPPy
ZiPPy
15 years 2 months ago #33558 by iR1sH
L2cisco ---roommate!
