Need help on my network...
15 years 2 months ago #33470
by zErOaCid
Need help on my network... was created by zErOaCid
Hi, i'm just new to this CISCO. I'm trying to configure my 1st network which is:
Did all the subnetting to the ip class: 192.168.0.0/24
4 routers (ring topology):
192.168.0.24/30 - router 1
192.168.0.28/30 - router 2
192.168.0.32/30 - router 3
192.168.0.36/30 - router 4
Network A:
192.168.0.1/28
- connected to router 1
- connected to switch A
Network B:
192.168.0.16/29
- connected to router 3
- connected to switch B
I have already configured but it's not working. I can do pings on the same network. But when i try to ping a host on the other network is not working. any ideas that i need to check with my configuration? thanks.
Network A:
192.168.0.1/28
Network B:
192.168.0.16/29
15 years 2 months ago #33471
by Nevins
Useful Threads
Replied by Nevins on topic Re: Need help on my network...
Your going to need to provide more information.
I would start by putting the results of show run in for each node into a paste bin.
In the mean time here is a good example of how to configure the most common routing protocols.
Useful Threads
15 years 2 months ago #33616
by Losh
Replied by Losh on topic Re: Need help on my network...
what you need to do is tell the router how to reach the host connected to another router.
you do this by configuring either a static route or any routing protocol you know.
I suggest you read more about default gateways, static routes or dynamic routes.
hope this helps abit.
