Routing : Static Route & OSPF
15 years 3 months ago #33361
by apit
Routing : Static Route & OSPF was created by apit
15 years 3 months ago #33379
by novembre
Replied by novembre on topic Re: Routing : Static Route & OSPF
Yes its possible. You have a default route at your Branch office pointing towards the HQ, the HQ office would have static route for the subnet you've allocated for the Branch office.
Since the site has only one WAN link, you don't get any benefits from the routing protocol in the event of link failure.
The only drawback is limits on scalability and the associated administrative burden. If you add another branch office, you will need to manually update the routing table etc. If this ends up at 100 sites you might want an IGP.
For that network, I'd just use static routes.
15 years 3 months ago #33380
by novembre
I should note I've assumed you allocated one large subnet to your branch. If someone setup something silly like 20 non-contiguous IP subnets to the Branch office (I've seen something similar) you might want to consider IGP. You also need to redistribute the static default route into OSPF which is straight forward.
Time to create page: 0.239 seconds
