Port forwarding error!!!!!
15 years 3 months ago #33163
Replied by S0lo on topic Re: Port forwarding error!!!!!
jester, if you do port forwarding correctly, it will allow you to access it both from internet and LAN. I've done this before as many others did, there is really no difficulty in it if you set it right. Here is the exact step by step instructions for your exact model "Billion Bipac-5200"
www.portforward.com/english/routers/port.../Bipac-5200/HTTP.htm
As it is shown, you have to setup a "Virtual Server", not DMZ. Just replace port 80 with port 8000 (as you said). Do as shown and tell us what happens. Again, the IP of the DVR should remain 192.168.2.2
15 years 3 months ago #33164
by FlipRich
Rich
Network Engineer /CCNP, CCNA-S
Tallahassee, FL
Replied by FlipRich on topic Re: Port forwarding error!!!!!
DMZ? Do you have the device on a seperate subnet or vlan than the rest of the network?
Also, does your Billion router have an extra inside interface on it?
Rich
Tallahassee, FL
15 years 3 months ago #33170
by jester
Replied by jester on topic Re: Port forwarding error!!!!!
No, the device is on the same Subnet and it is not having a separate interface ,its just a isp provided modem cum router .
I will once again try to configure the virtual server as per s0lo.
I really thank every one for their response.
15 years 3 months ago #33172
by jester
very thing went fine and i can now access the DVR ,but its throwing an error msg "device busy"
15 years 3 months ago #33176
What is throwing "device busy"? The DVR? the router? And on what screen/GUI/CLI is it throwing it? Please elaborate.
Time to create page: 0.240 seconds
