how do i start wireless WLAN zero configuration?
- lmcares4u2003
- Junior Member
15 years 4 months ago #32820
by lmcares4u2003
how do i start wireless WLAN zero configuration? was created by lmcares4u2003
after turnin on wireless zero configuration , yes have don dis @ services.msc.........after change it from stopped to started then it works but after re-starting my system i cant see any wireless network again which means i have 2 go back 2 services.msc and re-start the program.........what do i do to make it permanent?
15 years 4 months ago #32823
by KiLLaBeE
Replied by KiLLaBeE on topic Re: how do i start wireless WLAN zero configuration?
Check to see whether it's startup type is set to Automatic vs Manual. Simply double-click the service and you'll see the drop down menu.
Also, check whether there's another wireless manager on the computer taking over that responsibility. HP laptops, for example, come with extra software to help you manager the wireless...I uninstall them.
15 years 4 months ago #32826
Replied by TheBishop on topic Re: how do i start wireless WLAN zero configuration?
D-Link software is another common culprit for the above
- lmcares4u2003
- Junior Member
15 years 4 months ago #32843
by lmcares4u2003
Replied by lmcares4u2003 on topic Re: how do i start wireless WLAN zero configuration?
ok, i will try dat
