internet connection on vlan switch
15 years 5 months ago #32442
by sose
sose
Network Engineer
internet connection on vlan switch was created by sose
i have a cisco 2900 series switch have three vlan including the the default vlan. and a cable coming from my router to the switch. will all vlan get internet connection, is it necessary to link the router and the swith through a trunk port
sose
Network Engineer
15 years 5 months ago #32447
by Kajitora
itgamers.blogspot.com
Replied by Kajitora on topic Re: internet connection on vlan switch
I dont want to say thats the ONLY way, but a router on a stick would probably be your best bet. Below is a configuration example for vlan 20 & 25.
On switch
interface fastethernet 1/0/1
switchport trunk encapsulation dot1q
switchport mode trunk
On Router
interface fastethernet0
no ip address
interface FastEthernet 0.20
ip address 10.1.20.1 255.255.255.0
encapsulation dot1q 20
interface FastEthernet 0.25
ip addres 10.1.25.1 255.255.255.0
encapsulation dot1q 25
On switch
On Router
no ip address
15 years 5 months ago #32464
Replied by Chris on topic Re: internet connection on vlan switch
Sose,
You can also follow our detailed example in the Cisco Technical Knoweldgebase:
www.firewall.cx/tk-cisco-routers-on-stick.php
15 years 5 months ago #32465
by sose
sose
Network Engineer
Replied by sose on topic Re: internet connection on vlan switch
yea i have gone through that chris
thanks
thanks
sose
Network Engineer
