ipsec l2l tunnel between 5505 and 5540
16 years 11 months ago #32302
by ixfnx
ipsec l2l tunnel between 5505 and 5540 was created by ixfnx
I'm having trouble getting the tunnel up between the two devices. please take a look and tell me I've left out something silly. here is the config from the 5505, the 5540 is good as I have several other 1841's connected to the device over ipsec vpn.
ASA Version 8.2(1)
hostname cr201
domain-name bizcom.com
enable password <removed> encrypted
passwd <removed> encrypted
names
interface Vlan1
no nameif
no security-level
no ip address
management-only
interface Vlan2
description outside ISP connection
nameif outside
security-level 0
ip address A.B.C.13 255.255.255.0
interface Vlan3
nameif inside
security-level 100
ip address 10.201.201.1 255.255.255.0
interface Ethernet0/0
description outside network
switchport access vlan 2
interface Ethernet0/1
description inside network
switchport access vlan 3
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
ftp mode passive
clock timezone EST5EDT -5
dns server-group DefaultDNS
access-list 100 extended permit ip 10.201.201.0 255.255.255.0 172.20.0.0 255.255.255.0
access-list 100 extended permit ip 10.201.201.0 255.255.255.0 172.21.1.0 255.255.255.0
access-list 100 extended permit ip 10.201.201.0 255.255.255.0 172.30.0.0 255.255.255.0
access-list 100 extended permit ip 10.201.201.0 255.255.255.0 172.30.1.0 255.255.255.0
access-list 100 extended permit ip 10.201.201.0 255.255.255.0 10.0.219.0 255.255.255.0
pager lines 24
logging enable
logging timestamp
logging monitor debugging
logging buffered debugging
logging trap debugging
logging history debugging
logging facility 18
logging device-id hostname
mtu outside 1500
mtu inside 1500
no asdm history enable
arp timeout 1440
global (outside) 1 interface
nat (inside) 0 access-list 100
route outside 0.0.0.0 0.0.0.0 A.B.C.13 1
timeout xlate 3:00:00
timeout tcp-proxy-reassembly 0:01:00
aaa-server authbiz protocol tacacs+
aaa-server authbiz (inside) host 172.30.0.4
timeout 5
key <removed>
aaa authentication telnet console authbiz LOCAL
aaa authentication enable console authbiz LOCAL
aaa authentication ssh console authbiz LOCAL
snmp-server community *****
crypto ipsec transform-set foo esp-3des esp-md5-hmac
crypto map biz 10 match address 100
crypto map biz 10 set peer A.B.C.2
crypto map biz 10 set transform-set foo
crypto map biz interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
ssh A.B.C.D 255.255.255.0 outside
ssh 10.0.219.0 inside
ssh timeout 5
console timeout 0
dhcpd ping_timeout 750
dhcpd domain bizcom.com
dhcpd address 10.201.201.101-10.201.201.132 inside
dhcpd enable inside
threat-detection basic-threat
ntp server 172.30.1.121 source inside
username admin password <removed> encrypted privilege 15
tunnel-group A.B.C.2 type ipsec-l2l
tunnel-group A.B.C.2 ipsec-attributes
pre-shared-key *
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect http
prompt hostname context
end
ASA Version 8.2(1)
hostname cr201
names
interface Vlan1
no nameif
no security-level
no ip address
management-only
interface Vlan2
nameif outside
security-level 0
interface Vlan3
nameif inside
security-level 100
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
ftp mode passive
pager lines 24
logging enable
logging timestamp
logging facility 18
mtu outside 1500
mtu inside 1500
arp timeout 1440
timeout 5
key <removed>
encryption 3des
hash md5
group 2
lifetime 86400
ssh timeout 5
console timeout 0
dhcpd enable inside
pre-shared-key *
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect http
end
16 years 11 months ago #32330
by ikon
Replied by ikon on topic Re: ipsec l2l tunnel between 5505 and 5540
Where is the other ends config?
Looks ok but you dont have any access lists allowing traffic from inside to the VPN, you have crytomap access lists to tell the vn what the interesting traffic is, it might be that the VPN is connected but traffic is not flowwing because of ACL?
do you have any logs?
enable syslog or look in the ASDM for syslog messages.
