Frame Relay
15 years 7 months ago #31726
by pedenski
Frame Relay was created by pedenski
lately ive been studying frame relay.. and so there I was.. the moment of configuration..
i have this diagram from the book
now.. please correct me if im wrong..
this is a global addressing right?
if so, if i wanted to frame relay mayberry to mountpilot then i would use this command..
Mayberry
#int se0/0/0
#ip add 199.1.1.1 /24
#encap frame-relay
#frame-relay map ip 199.1.1.2 51 broadcast
now i was wondering, what if i wanted to add raleigh on my frame relay also, should i use the
#frame-relay map ip 199.1.1.3 51 broadcast
aswell?
shouldnt be the correct config for frame relay is
#frame-relay map ip <remote ip> <local dlci> broadcast
[/b]
Mayberry
#int se0/0/0
#encap frame-relay
aswell?
[/b]
15 years 7 months ago #31727
by pedenski
Replied by pedenski on topic Re: Frame Relay
somehow the book says the frame relay command
for mayberry is
#int se0/0/0
#frame-relay map ip 199.1.1.2 52 broadcast
#frame-relay map ip 199.1.1.3 53 broadcast
im confused whats the correct command, when i use a frame relay at packet tracer, the book's config
#frame-relay map ip <destination ip> <remote DLCI> broadcast
doesnt work..
but the
#frame-relay map ip <destination ip> <local DLCI> broadcast
works
for mayberry is
#int se0/0/0
doesnt work..
but the
works
15 years 7 months ago #31731
by ZiPPy
ZiPPy
Replied by ZiPPy on topic Re: Frame Relay
This lab from TechExams.net really helped me understand and successfully configure a Frame Relay network.
Run through the lab, then compare your config to the labs.
www.techexams.net/techlabs/ccna/lab_fr.shtml
ZiPPy
ZiPPy
ZiPPy
15 years 7 months ago #31732
by pedenski
well, thanks for posting that tho.. ive learned some new things.. but i would really appreciate if my specific problem would be answered..
15 years 7 months ago #31762
Replied by S0lo on topic Re: Frame Relay
The DLCI you should use is Local. However, The diagram above is not really clear weather those are local or remote because there should be more DLCIs there. Each connection (PVC) should show two DLCIs one at each end.
Check the diagram that ZiPPy posted or here for example:
www.cisco.com/en/US/tech/tk713/tk237/tec...8a7.shtml#netdiatop4
The config for the router on the left in this scenario should look something like this:
[code:1]interface Serial0
ip address 4.0.1.1 255.255.255.0
frame-relay map ip 4.0.1.2 140 broadcast
frame-relay map ip 4.0.1.3 130 broadcast
encapsulation frame-relay
Notice that both 130 and 140 are local to the router.
This packet tracer labs series for frame relay might help: www.firewall.cx/ftopic-3972-days0-orderasc-0.html
My 1000 post here!! I love frame relay
15 years 7 months ago #31763
by ZiPPy
ZiPPy
That is an awesome link S0lo, and has come in very handy in troubleshooting my Frame Relay lab. I made a few changes according to that documentation that have really helped.
Congrats on the 1000 post too!!
ZiPPy
ZiPPy
ZiPPy
