remote connection over the internet
15 years 7 months ago #31523 by next_virus
I think you want to access your home PC from your office or vice versa.
If this is the situation then you can install team viewer, uvnc, or any remort control s/w. I preffer Team Viewer as it is very easy to install and use.
Regards
15 years 7 months ago #31610 by factory909
x2 on the Team Viewer. It will be free for your situation.
15 years 7 months ago #31614 by ZiPPy
Why use a 3rd party software, when you have the built in capability of RDP in Windows with a few adjustments to your firewall? Everytime you install 3rd party apps, your creating overhead. Noticeable? Yes ...how much depends on the app.
Remember, these 3rd party remote type access apps can be exploited very easily. This will be even more apparent when updates and patches are released for the product.
ZiPPy
ZiPPy
