cant go through a cisco device
starting from the switch, i have followed the link to bypass the password but couldnt, becos it need the access password
here is my output
Base ethernet MAC Address: 00:19:30:51:fa:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 600 files, 19 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 7712256
flashfs[0]: Bytes available: 24801792
flashfs[0]: flashfs fsck took 10 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c2960-lanbase-mz.122-25.SEE2/c2960-lanbas
File "flash:c2960-lanbase-mz.122-25.SEE2/c2960-lanbase-mz.122-25.SEE2.bin" uncom
pressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restrict
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(25)SEE2, RELE
ASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 04:33 by yenanh
Image text-base: 0x00003000, data-base: 0x00AA2F34
Initializing fla
flashfs[1]: 600 files, 19 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32514048
flashfs[1]: Bytes used: 7712256
flashfs[1]: Bytes available: 24801792
flashfs[1]: flashfs fsck took 1 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Waiting for Port download...Complete
cisco WS-C2960-24TT-L (PowerPC405) processor (revision B0) with 61440K/4088K byt
es of memory.
Processor board ID
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:19:30:51:FA:80
Motherboard assembly number : 73-10390-03
Power supply part number : 341-0097-02
Motherboard serial number : FOC11011149
Power supply serial number : DCA10518APE
Model revision number : B0
Motherboard revision numbe
Model number : WS-C2960-24TT-L
System serial number : FOC1102Z0EQ
Top Assembly Part Number : 800-27221-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COM3L00BRA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C2960-24TT-L 12.2(25)SEE2 C2960-LANBASE-M
Press RETURN to get started!
00:00:39: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state t
o down
00:00:39: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:00:41: %SYS-5-CONFIG_I: Configured from memory by console
00:00:41: %SYS-5-RESTART: System restarted --
ASE SOFTWARE (fc1)
User Access Verification
Password:
% Password: timeout expired!
Password:
The system has been interrupted prior to initializing the
flash filesystem. The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
flash_init
load_helper
boot
switch: flash_init
Setting console baud rate to 9600...
switch: load_helper
switch: dir flash
unable to stat flash/: no such device
switch: rename flash:confi.txt flash:config.old
rename: no such file or directory
switch: dir
List of filesystems currently registered:
flash[0]: (read-write)
xmodem[1]: (read-only)
null[2]: (read-write)
bs[3]: (read-only)
switch:
and regarding the router when i start it i get rubbish may be a corrupted ios
here is my output
àv´&øþï=&øþ¹v¹ù&¹v·6ùxþ6v=£:ë{«:›ùøøøøøøøøøøøøõøøøøøøøøøøøøøøøøøøøøøøøøøøøøøøõø
øøøøøøøøøøøøøõôõøýøøøøøøüøøøøøôôøøüøøýøøøøøøýøøõøøøøøøøøøøøýøøøøøôôøøøøøüøøôøøüø
øøøøøøøøøøøøxßüŸøþöüü öýýþøüþøþý øýýþ üøüýøþ üþüþôýþüþüùøøüøøýýø üýøüýýýýþüüôýøü
÷ýþ ýþøþýý üþýøùøþýþ öüü õýùøþüýü þøüýü þýøü øýüþøþýõùøûúùúúûùúúøüýýøþ üþüþüýþ
üöüùøøüøøøúøøøüüøøŸ ùüôþýúôúþûúúûýüüúùøýü üùüüþýúôúþûôûúúúúúùøùø þýýõøýýùùøýþ
ýý øüý ýþýüüõþùøúøýý ùþþýýýøþýþüüýøöþýü÷üþþýüøøüý ýþýüüýþùøýþüóøüýýýüý þü üýýøôý
ýøó þüýùùøûúûúúüøüþ ý÷øýýôü üøüýýþüü ýýüþüøøöýüý÷ þü ýøùøíˆî
sose
Network Engineer
- dentifrice
and notice the config.TEXT (not .txt)
switch: dir flash
it is actually this command, same with semicolon to access the flash root directory:
switch: dir flash:
Please re-do the password recovery procedure and do your best to not mistype any critical commands. you tried to re-name the configuration file and you mistyped the file name here too.
it is called config.text, and your command included config.txt! you see a slightly mistyping or missing characters could lead to frustrations
here is the right command:
switch: rename flash:config.text flash:config.old
I hope this time the recovery will works properly.
about your Router I have not seen such output before but as you said there is a big chance it is a corrupted IOS or a corrupted CF card. try removing the CF card and see if the IOS will boot the mini recovery version from its ROM and it should put you in ROMmon> mode. if such so you could then download a clean IOS version uploaded to a TFTP server and copy it to override the corrupted one you have in your CF card.
good luck.
system software:
flash_init
load_helper
boot
switch: flash:init
Unknown cmd: flash:init
switch: flash_init
switch: load_helper
switch: dir flash:
Directory of flash:/
2 -rwx 5 <date> private-config.text
3 -rwx 556 <date> vlan.dat
5 drwx 192 <date> c2960-lanbase-mz.122-25.SEE2
620 -rwx 1298 <date> config.text
24801792 bytes available (7712256 bytes used)
switch: rename flash:config.txt flash:config.old
switch: config.txt
Unknown cmd: config.txt
switch: ?
? -- Present list of available commands
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash fil
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
load_helper -- Load and initialize a helper image
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_bs -- Set attributes on a boot sector filesystem
set_param -- Set system parameters in flash
sleep -- Pause (sleep) for a specified number of seconds
-- MORE --
trap -- Cause a software breakpoint to occur
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
switch: rename ?
usage: rename <old_name> <new_name>
switch: rename flash:config.old flash:config.txt
switch:
can i download ios from cisco sites, ho0w do I the reload my router flash memory
sose
Network Engineer
look to the out the switch throw when you used the commnad dir flash:
[code:1]switch: dir flash:
620 -rwx 1298 <date> config.text[/code:1]
look to the fourth output line:
check the file name it is config.text, the extension is text actually and not the one we are custom to in windows txt the is a slightly difference and that is the e character shows up in cisco config.text
here is what you are expexted to type correctly for it to work:
[code:1]switch: rename flash:config.txt flash:config.old [/code:1]
good luck, don't surrender
[code:1]switch: rename flash:config.text flash:config.old [/code:1]
