telneting
15 years 10 months ago #30570
by sose
sose
Network Engineer
I have connected 2 PCs together with a cross cable running xp, how do I enable telnet and telnet on the other computers command line
thanks
thanks
sose
Network Engineer
15 years 10 months ago #30572
by KiLLaBeE
Replied by KiLLaBeE on topic Re: telneting
Enable and start the telset service on both computers by going to Start > Run, and type services.msc and hitting OK. When the Services window comes up, find Telnet, change the startup type to manual (or automatic), and click the Start button (do this on both computers).
Then to telnet to the other computer, go to the command prompt and type telnet %IP_addr_of_other_comp% and hit Enter
15 years 10 months ago #30577
by sose
sose
Network Engineer
Replied by sose on topic Re: telneting
thanks man
sose
Network Engineer
15 years 10 months ago #30594
by sose
sose
Network Engineer
hey!!
I enabled telnet and telnetted an IP address, but it kept denying me acces or closing my connection.
it told me to create a telnetclient group and import members which i did but couldnt connect. It also told me that shell process not running , quite a headache men
sose
Network Engineer
15 years 10 months ago #30595
by KiLLaBeE
Like this?
Add the username that you're telnetting with to the Administrators group on the remote computer.
I replicated this like this:
1. Created the same user account (i.e.: test) on both computers (member of the Users default group)
2. Telnetted to the remote computer and got the error
3. Added the user account (test) to the Administrators group on the remote computer
4. Telnetted again and got in successfully
15 years 10 months ago #30602
by talk2sp
Sose KillaBeE is right. u have to create an account for both systems. for example. system A and system B.
you do this> System A u create an account for system b which will be ur user name when u want to log on to system A and vice versa.
CODE3
BORN TO BE GREAT
c0de - 3
Replied by talk2sp on topic the only way.....
CODE3
BORN TO BE GREAT
c0de - 3
