which is better;DHCP or STATIC routing on Cisco2600 IOS v.12
15 years 10 months ago #30489 by redst
Hi to everyone;
I just want to get some advice from you guy's if is better to use dhcp addressing or static on our network.
currently we have 2 internet lines connected to one router only using serials so we can do load balancing,but every now and then we lose connection, and time outs occur frequently.do you think the way the router was config is the problem co'z we already use a different router and the problem is the same.and also where can i find the commands used for the cisco2600 IOS v.12.0..
thank you in advance..
Time to create page: 0.177 seconds
