Please help me
15 years 11 months ago #30337
by wiggy
Bhongsky
Please help me was created by wiggy
Sir can you please teach me on how to add wireless conncetion to my wired connection network, what is the steps by steps procedure on how to implement this. I would like also to set a wireless device as DCHP configured can you tell me on how to do this shall I configure it to the primary router or shall I configure in in the wireless device. By the way the wireless device is linksys. Please sir help me you can email me at pg.gapuz@gmail.com
Many thanks
Paul
Many thanks
Paul
Bhongsky
15 years 11 months ago #30339
by Alans
always Face your Fears...
Replied by Alans on topic Re: Please help me
Connect Linksys device to any network port (cable network) using same cable as you use for connection computers to the network.
Then give the Linksys IP, default gateway and DNS. (refer to Linksys's documents)
As for DHCP, if you want only your wirless clients to have DHCP IP then use the DHCP in the Linksys, if you want your Cable network to have DHCP IP then you can use Windows Server 2003 or 2000 as DHCP server.
With proper googling and reading you can do what you asked for easily
