VRF Light
16 years 2 months ago #29794
by Chojin
Hi all,
Any of you any experience with VRF Light?
Currently I have the following challenge.
I would like to seperate a couple of VLAN's from other VLAN's and would route them to a seperates firewall. They are not allowed to communicate outsite these VLAN-group.
[Core-Switch]
VLAN1
VLAN2
VLAN3
VLAN4
VLAN5
VLAN6
VLAN7
VLAN 1-2-3-4 are able to communicate with eachother and the rest of the network (routed)
VLAN 5-6-7 may communicate with eachtother, but NOT with the rest of the network.
Now, i would like to attach an interface of the Firewall on the Core-switch in VLAN-8
Have VLAN 5-6-7 communicatie with 5-6-7-8.
For this I think VRF-Light is a nice way to distinguish these.
Thanks for the responses in advance
greetings Chojin
[Core-Switch]
VLAN1
VLAN2
VLAN3
VLAN4
VLAN5
VLAN6
VLAN7
greetings Chojin
16 years 1 month ago #29855
by Chojin
Replied by Chojin on topic Re: VRF Light
As always things will work
Got VRF-Light working at the moment, see below the config of my 3750:
Current configuration : 3975 bytes
version 12.2
no service pad
service timestamps log uptime
hostname Switch2
boot-start-marker
boot-end-marker
enable secret 5 show_me_the_money
username cisco password 0 cisco <-- this is a secret
no aaa new-model
switch 1 provision ws-c3750-24p
system mtu routing 1500
ip subnet-zero
ip routing
no ip domain-lookup
ip vrf test
rd 1:1
route-target export 1:1
route-target import 1:1
ip vrf test2
rd 2:2
route-target export 2:2
route-target import 2:2
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
spanning-tree extend system-id
vlan internal allocation policy ascending
interface Loopback1
ip vrf forwarding test
ip address 1.1.1.1 255.255.255.255
interface FastEthernet1/0/1
switchport trunk encapsulation dot1q
switchport mode trunk
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
interface FastEthernet1/0/24
no switchport
no ip address
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.3 255.255.255.0
standby 1 ip 192.168.10.254
standby 1 priority 90
standby 1 preempt
standby 1 track GigabitEthernet1/0/1 25
interface Vlan20
ip vrf forwarding test2
ip address 192.168.10.2 255.255.255.0
interface Vlan999
ip address 192.168.99.2 255.255.255.0
ip classless
ip http server
ip http secure-server
control-plane
alias exec s show ip int brief | e unas
alias exec si show int status | e notcon
line con 0
exec-timeout 0 0
logging synchronous
line vty 0 4
password cisco <-- this is a secret, don't tell anyone plz
login
line vty 5 15
login
end
version 12.2
no service pad
hostname Switch2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip routing
no ip domain-lookup
ip vrf test
rd 1:1
ip vrf test2
rd 2:2
interface Loopback1
no switchport
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan10
standby 1 preempt
interface Vlan20
interface Vlan999
ip classless
ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
end
Time to create page: 0.080 seconds
