Using Static IP's behind a Cisco ASA-5505
16 years 2 weeks ago #29697
by timparker
Replied by timparker on topic Re: Using Static IP's behind a Cisco ASA-5505
Can you post your config? If they are on an inside interface, they shouldn't need a rule. Higher security to lower should work by default.
16 years 2 weeks ago #29698
by kithylin
Replied by kithylin on topic Re: Using Static IP's behind a Cisco ASA-5505
i'll re-connect the cisco and look at it in a little while, went ahead and took it off until i can figure it out.
16 years 2 weeks ago #29699
by kithylin
I tried a port-forwarding guide to try and forward port 3724 to one of the ip's assigned through the 5505's dhcp service, 3724 tcp for u-torrent, but that didn't work either, i should probably delete that in a bit.
Result of the command: "show running-config"
: Saved
ASA Version 7.2(2)
hostname ciscoasa
enable password Yn8Esq3NcXIHL35v encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
object-group service uTorrent-3724 tcp
description uTorrent(3724)
port-object range 3724 3724
access-list outside_access_in extended permit tcp any object-group uTorrent-3724 interface outside object-group uTorrent-3724
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
static (inside,outside) tcp interface 3724 192.168.1.26 3724 netmask 255.255.255.255
timeout xlate 3:00:00
http server enable
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.129 inside
dhcpd enable inside
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
prompt hostname context
Cryptochecksum:d0664dae2b1694f06941b2ba0ab64a1d
: end
: Saved
ASA Version 7.2(2)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
: end
- Chris71Mach1
15 years 10 months ago #30316
by Chris71Mach1
Replied by Chris71Mach1 on topic Re: Using Static IP's behind a Cisco ASA-5505
well kithylin, theres some good news and some bad news for ya on this one. the good news is that the box that you used as an example in your first post in this thread is easily fixed. if you drop to a shell, youll notice that you can ping 4.2.2.2 just fine, and that the box actually CAN reach the internet through your ASA5505. the solution to this problem is to manually point your box(es) on your network to a dns server, cause your problem isnt DHCP related, port related or anything, but ultimately a DNS issue. in linux (which it looks like your example box is in that first post), you just wanna edit your /etc/resolv.conf file and add a nameserver to it. this will basically tell your box to use that nameserver for your dns lookup requests. on any windows box of course, you just wanna exit the tcp/ip properties of your network interface and add a dns server manually. once you do this, youll have no problem at all resolving DNS and browsing the web.
the bad news is kinda 2 fold. (1) ive found that the ASA5505 is not at all capable of acting as a dns server. i find this is a surprising shortcoming of this device, as i previously couldnt imagine a hardware firewall/router device that couldnt act as a fully functional DNS and DHCP server. (2) despite my best efforts (and believe it or not, my research for this problem brought me to this thread to begin with), I am finding that if you want static IP's on a network that is behind a 5505, you may have to set your IP's on the client side instead of the DHCP server. my personal preference is to configure a DHCP server to assign a particular IP to a particular MAC ID that requests an IP, but unless I am just totally missing something, I dont think this can be done.
anyways, good luck with your intro into cisco (and wow, a 5505 is a hell of a way to get your feet wet with cisco hardware, but hey, ya gotta start somewhere, right?!)
