Connecting 2 or more sites together over MPLS
16 years 2 months ago #28990 by Chicago_Techie
Hi. I have some routing experience but I don't have much experience routing over a service providers MPLS network and had some questions..
Say I had 3 sites in different cities. I want to be able to route my data traffice to each site. I would like to use a MPLS provider.
Does the provider hand-off copper and/or fiber to me?
If fiber, is it usually single mode for anything above 10 megabits?
Would the hand-off be a layer 2 or 3 hand-off?
If layer 2, do I trunk with the providers directly connected interface/port?
If layer 3, do I "peer" with the providers directly connected interface with a routing protocol?
If I want to use EIGRP between my 3 sites, can I configure them to all be in the same AS?
I'm assuming I would need a layer2 and or layer 3 device at each of the locations to interface into the provider. What type of router/layer3 switch would be good for something like this? (Must be able to handle heavy traffic. Say, sustained 40 megabit throughput throughout the day.)
Does anyone know of or have any configuration samples/diagrams of the "customer side" of routing over MPLS? (I've seen a lot of docs on configuring MPLS but that's not what I want to do.) My goal is to interface with the carrier to use their backbone and just pass/route my data-traffic to my different sites.
Any advice/pointers/help would be GREATLY appreciated!
:D
Time to create page: 0.169 seconds
