communication between subnets
16 years 3 months ago #28671 by Lav_plsb
In order to communicate between two different subnets. (for ex.192.168.0.35/255.255.255.224 and ip:192.168.0.10/255.255.255.224 ) I am planning to use Router. Which Router is best and the model number of the router and how to configure if it is cisco router.
  • gagamboy
  • Visitor
  • Visitor
16 years 3 months ago #28675 by gagamboy
Replied by gagamboy on topic Re: communication between subnets
Hi Lav_plsb,
I think it will depend on your network requirements, number of users, topology, etc..
For the configs:
IP default-gateway can be used.
*It is better to show us your network setup/config/topology so we can assist you.
Cheers!
Gagamboy
16 years 3 months ago #28684 by S0lo
The Cisco 2800 series routers can be a good candidate for deployment in real networks. You might wana see the 2801 or 2811 specs. If budget is an issue, you could grab a used/refurbished 2621XM or any 2600 series router that fits your needs. As for your configuration, some thing similar to this would be needed:
[code:1]Router(config)# interface FastEthernet0/0
Router(config-if)# ip address 192.168.0.35 255.255.255.224
Router(config-if)# no shutdown
Router(config-if)# interface FastEthernet0/1
Router(config-if)# ip address 192.168.0.10 255.255.255.224
Router(config-if)# no shutdown[/code:1]
Sure you need to configure IPs/masks/gateways on each PC of the two networks. Or you could use DHCP to automate that.
As gagamboy suggested, it would help more if you detail your network for us.
