Inter VLAn routing between 4 cisco 3750 switches
16 years 5 months ago #28174 by dell
Hi i have a query regardin intervlan routing between 4 cisco 3750 switches
The 3 main switches ( A,B,C)are connected in triangle shape. These switches form the bachbone of the network
A new switch is connected between A and B this form a new triangle
Link for the network diagram :-
www.box.net/shared/597r13f4i3
how to enable routin between the switches
can any one give the sample configuration of the routing like static or OSPF in cisco 3750 switches
thanking you in advance
dell
16 years 4 months ago #28508 by valkyrnash
First, to enable routing on a layer 3 switch, in PRIV EXEC, run "ip routing", this will turn routing on on the switch, as it is not enabled by default. Then on the interfaces you want to do the routing, enter "no switchport". You will then be able to assign IP addresses, etc for this port. For Cisco's documentation on it, go to: www.cisco.com/en/US/tech/tk389/tk815/tec...186a008019e74e.shtml
For a barebones configuration, see below ( I assumed sw A from the diagram for this config)
Current configuration : 1452 bytes
version 12.2
hostname Switch
ip routing
ip ssh version 1
port-channel load-balance src-mac
interface FastEthernet0/1
no switchport
ip address 10.1.2.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/2
no switchport
ip address 10.1.1.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/3
no switchport
ip address 10.1.5.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 10.2.0.1 255.255.0.0
interface Vlan3
ip address 10.3.0.1 255.255.0.0
interface Vlan10
ip address 10.10.0.1 255.255.0.0
router ospf 1
log-adjacency-changes
ip classless
ip route 0.0.0.0 0.0.0.0 200.0.0.1
line con 0
line vty 0 4
login
end
16 years 4 months ago #28509 by Kajitora
The above is correct. I would suggest having the VLAN interface do the routing through.
So you would use the "ip routing" command. But also, for each VLAN.
"int vlan 10"
"ip address x.x.x.x x.x.x.x"
"no shut"
The ip address of the vlan should be your default gateway for that VLAN. Once you do the ip routing command all normal routing commands will become avialble so you will be able to put a gateway of last resourt if you have a edge router you need it to rout to.
itgamers.blogspot.com
