two dhcp servers clashing on thesame LAN
16 years 5 months ago #28169
by sose
sose
Network Engineer
Replied by sose on topic Re: two dhcp servers clashing on thesame LAN
how did you assign your IPs, the problem I had was two dhcp servers on one subnet please can you give us a detailed config
thanks
thanks
sose
Network Engineer
16 years 5 months ago #28198
by talk2sp
BORN TO BE GREAT
c0de - 3
Replied by talk2sp on topic pf sense manuals....
hey sose install pf sense on ur server and then if u want a detailed config on the network setup check out the pfsense docs manual on their site. its a flash file i guess...
what internet modem are u using?
BORN TO BE GREAT
c0de - 3
16 years 5 months ago #28199
by talk2sp
BORN TO BE GREAT
c0de - 3
Replied by talk2sp on topic i just verified....
hey man sose i just verified with another network admin... he did not disable anything on the idirect modem nor did he disable anything wen he configured his pfsense server....
BORN TO BE GREAT
c0de - 3
16 years 4 months ago #28390
by sose
sose
Network Engineer
there was kind of a mixed up in my brain solo you were right. a couple of months ago I configured a linksys with a live IP but now i am configuring with a private IP so there is kind of a mixed up in the cable placement in the LAN port and WAN port. since i am not using it as a router I need to place the cable from the modem into the LAN POrt.
even though I was a ble to hack into the modem to disable the dhcp but this is an important observation
thank you all
thank you all
sose
Network Engineer
16 years 4 months ago #28403
by talk2sp
BORN TO BE GREAT
c0de - 3
Replied by talk2sp on topic hack.................?
sose hack..................?
BORN TO BE GREAT
c0de - 3
