network connectivity problem
16 years 8 months ago #27475 by sose
problem: 5 sysem network hangs
I have a five system network including a server 2003 running peachtree service only.
the problem is that sometime the server hangs until i disable and enable the LAN icon before it picks up. this mostly happens when other peachtree clients are sending data to the 2003 server. kind of a network connectivity problem I guess
any help
16 years 8 months ago #27483 by Patiot
Could you elaborate on the issue with the details about your network equipment like what switch do you use and how do you configure them ?
Patiot
16 years 8 months ago #27486 by sose
8 port dlink switch
cat 5 e cable
16 years 8 months ago #27488 by Patiot
Are you able to ping the server when other clients are sending data to the server .
Patiot
Time to create page: 0.099 seconds
