Monitoring Cisco equipement
- dentifrice
16 years 6 months ago #27405
by dentifrice
Monitoring Cisco equipement was created by dentifrice
Hi guys,
I'm looking for a monitoring system for Cisco switches and some routers.
Which program do yo recommand ? Can be from Cisco or 3rd parties...
I need something "professional" with detailed status
Can CiscoWorks do that ?
thanks!
thanks!
16 years 6 months ago #27418
by sp1k3tou
Replied by sp1k3tou on topic Re: Monitoring Cisco equipement
What do you need to monitor? Ports,uptime ?
16 years 6 months ago #27429
Replied by TheBishop on topic Re: Monitoring Cisco equipement
Cisco Works will do what you want and probably more, but you'll pay a professional price for it. The other think is that it's the most convoluted piece of software (actually it's several bits of software crammed together and sold as if it were one) that I've ever worked with.
I'd recommend you list out the facilities you actually need/want then evaluate possible purchases against that. You'll get best value for your money that way
- dentifrice
16 years 6 months ago #27433
by dentifrice
Replied by dentifrice on topic Re: Monitoring Cisco equipement
thanks for the reply
In fact, I need something with a lot of information. Uptime, ports status, which ports are set in VLAN X.
So it's not just about monitoring but managing and viewing config of equipement. Like a central management console.
thanks
thanks
16 years 6 months ago #27441
Cisco Works then
16 years 6 months ago #27444
Replied by S0lo on topic Re: Monitoring Cisco equipement
You might wana check these too (not exactly what you want, but might help):
www.solarwinds.com/downloads/index.aspx?CMP=ILC-GNav-Downloads
www.paessler.com/tools
