ASA 5505 Outside interface crashing
16 years 7 months ago #27230 by xJJSilvax01
Hello,
I have a ASA 5505, seems to run pretty smooth but almost 4 or 5 times a week, the outside interface goes out. Internet, Email, everything. Could a misconfiguration cause this problem? To fix it and get the outside interface backup again I just do a system reload and that fixes it, for a few hours at least....
Here is my show run.
Thanks a lot!
Result of the command: "show run"
: Saved
ASA Version 7.2(3)
hostname fw01
domain-name xxx.xxx
enable password xxxxxxxxxxxxxxxx encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address X.X.0.1 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address X.X.X.18 255.255.255.240
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxxxxxxxxxxxxxxxx encrypted
ftp mode passive
dns server-group DefaultDNS
domain-name XXXX.XXX
object-group service RDP tcp-udp
port-object range 3389 3389
object-group service ExtensionPorts tcp-udp
port-object range 239 239
port-object range 242 242
port-object range 228 228
port-object range 231 231
port-object range 233 233
port-object range 244 244
port-object range 248 248
object-group service BCM tcp-udp
port-object range 1 65535
access-list inside_access_out extended permit udp any any eq domain
access-list inside_access_out extended permit gre any host X.X.40.1
access-list inside_access_out extended permit tcp any host X.X.40.1 eq pptp
access-list inside_access_out extended permit tcp any host X.X.0.4 eq 5222
access-list inside_access_out extended permit tcp any host X.X.0.4 eq ftp
access-list inside_access_out extended permit tcp any host X.X.0.2 eq www
access-list inside_access_out extended permit tcp any host X.X.0.3 eq www
access-list inside_access_out extended permit ip any host X.X.9.2
access-list inside_access_out extended permit ip any host X.X.0.13
access-list inside_access_out extended permit tcp any host X.X.0.4 object-group RDP
access-list inside_access_out extended permit tcp any host X.X.40.1 eq www
access-list inside_access_out extended permit tcp any X.X.20.0 255.255.255.0 object-group ExtensionPorts
access-list inside_access_out extended permit ip any host X.X.90.120
access-list inside_access_out extended permit icmp any any traceroute
access-list outside_access_in extended permit udp any any eq domain
access-list outside_access_in extended permit tcp any host X.X.X.24 object-group RDP
access-list outside_access_in extended permit tcp any host X.X.X.29 object-group RDP
access-list outside_access_in extended permit gre any host X.X.X.28
access-list outside_access_in extended permit tcp any host X.X.X.28 eq pptp
access-list outside_access_in extended permit tcp any host X.X.X.28 eq www
access-list outside_access_in extended permit tcp any host X.X.X.24 eq 5222
access-list outside_access_in extended permit icmp any any traceroute
access-list outside_access_in extended permit tcp any host X.X.X.24 eq ftp
access-list outside_access_in extended permit tcp any host X.X.X.22 eq www
access-list outside_access_in extended permit ip any host X.X.X.26
access-list outside_access_in extended permit ip any host X.X.X.21
access-list outside_access_in extended permit tcp any host X.X.X.23 eq www
access-list outside_access_in extended permit ip any host X.X.X.25
pager lines 24
logging enable
logging buffer-size 4098
logging trap debugging
logging asdm notifications
logging mail emergencies
logging from-address xxx
logging recipient-address xxxx level notifications
logging host inside X.X.20.4 format emblem
logging debug-trace
logging ftp-bufferwrap
logging ftp-server X.X.20.4 / xxxx xxxxxx
logging permit-hostdown
logging rate-limit unlimited level 5
mtu inside 1500
mtu outside 1500
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
nat-control
global (inside) 1 interface
global (outside) 1 interface
static (inside,outside) tcp X.X.X.29 252 X.X.20.1 3389 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.29 233 X.X.20.3 3389 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.29 239 X.X.20.6 3389 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.29 231 X.X.20.2 3389 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.29 248 X.X.20.7 3389 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.29 242 X.X.20.4 3389 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.24 8059 X.X.0.4 8059 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.24 3389 X.X.0.4 3389 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.24 ftp X.X.0.4 ftp netmask 255.255.255.255
static (inside,outside) tcp X.X.X.24 aol X.X.0.4 aol netmask 255.255.255.255
static (inside,outside) tcp X.X.X.24 5223 X.X.0.4 5223 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.24 5298 X.X.0.4 5298 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.24 5297 X.X.0.4 5297 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.24 5222 X.X.0.4 5222 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.23 www X.X.0.3 www netmask 255.255.255.255 dns
static (inside,outside) tcp X.X.X.23 3389 X.X.0.3 3389 netmask 255.255.255.255
static (inside,outside) tcp X.X.X.22 www X.X.0.2 www netmask 255.255.255.255 dns
static (inside,outside) X.X.X.26 X.X.0.13 netmask 255.255.255.255
static (inside,inside) X.X.X.26 X.X.0.13 netmask 255.255.255.255
static (inside,inside) X.X.X.28 X.X.40.1 netmask 255.255.255.255 dns
static (inside,outside) X.X.X.28 X.X.40.1 netmask 255.255.255.255 dns
static (inside,outside) X.X.X.21 X.X.9.2 netmask 255.255.255.255
static (inside,inside) X.X.X.21 X.X.9.2 netmask 255.255.255.255
static (inside,inside) X.X.X.22 X.X.0.2 netmask 255.255.255.255
static (inside,inside) X.X.X.24 X.X.0.4 netmask 255.255.255.255
static (inside,inside) X.X.X.23 X.X.0.3 netmask 255.255.255.255
static (inside,outside) X.X.X.25 X.X.90.120 netmask 255.255.255.255
access-group inside_access_out out interface inside
route outside 0.0.0.0 0.0.0.0 X.X.X.17 1
timeout xlate 3:00:00
http server enable
http X.X.0.2 255.255.255.255 inside
http X.X.0.3 255.255.255.255 inside
http X.X.20.4 255.255.255.255 inside
http X.X.0.4 255.255.255.255 inside
http redirect inside 80
no snmp-server location
no snmp-server contact
telnet X.X.20.4 255.255.255.255 inside
telnet X.X.0.3 255.255.255.255 inside
telnet X.X.0.4 255.255.255.255 inside
telnet X.X.0.2 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns X.X.0.2
dhcpd wins X.X.0.2
dhcpd domain xxx.xxx
dhcpd auto_config inside vpnclient-wins-override
dhcpd update dns both
dhcprelay server X.X.0.2 inside
dhcprelay enable outside
dhcprelay timeout 60
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
tftp-server inside X.X.20.4 /
smtp-server X.X.9.2
prompt hostname context
Cryptochecksum:25d3f822a8ac5ede7d0afa8687d5a029
: end
16 years 7 months ago #27243 by Elohim
What's the outside connected to? if your outside is connected to an "always on" link, you shouldn't have problems.
Hello,
Thanks a lot!
: Saved
ASA Version 7.2(3)
hostname fw01
domain-name xxx.xxx
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
logging enable
logging debug-trace
mtu inside 1500
mtu outside 1500
arp timeout 14400
nat-control
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns X.X.0.2
dhcpd wins X.X.0.2
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
smtp-server X.X.9.2
: end
16 years 7 months ago #27246 by xJJSilvax01
Thanks for the reply.
The outside interface is connected to our ISP...
I would assume its a always on link.
16 years 7 months ago #27253 by Elohim
You can try to send keepalives to the outside and see if your ocnnection stays up.
16 years 7 months ago #27278 by Patiot
If you see a traceback in your sh tech then you should be probably hitting a bug .
