Need Help for a Basic Configuration (PCs-ASA-Internet)
16 years 7 months ago #27184 by Oronar
I have delete this statement => static (inside,outside) 192.168.1.1 10.1.17.254 netmask 255.255.255.255
Now, I can't ping 10.1.17.254 from the ASA
Its doesn't work better
16 years 7 months ago #27185 by Elohim
Your access list is incorrect.
get rid of:
access-group outside-access in interface outside
If you are only allowing your inside hosts to surf the web (without restriction), you don't need any access list at all. You just need a global and a nat.
Please define what you want to do with your access-lists.
16 years 7 months ago #27211 by S0lo
On which interface your PC is connected to? try this on it:
switchport access vlan 1
