Help Network configuration with ASA 5505
16 years 9 months ago #26603 by buLLs
Hi =). I hope my english will be enough good to explain my problem :roll: and also my network skillz...i am very noob..but everyone has to start from somewhere =P
This is my actual network configuration.
internet -- pc
My ISP gave me this configuration:
IP : 89.201.240.176
Netmask : 255.255.255.0
default gateway : 89.201.240.1
DNS : 212.23.32.70
DNS2 : 212.23.33.70
following this rule i the ip of my computer is 89.201.240.176, default gateway 89.201.240.1, dns 89.201.240.1 and i can acces the web.
I just got an ASA 5505, i tryed to configure it but i'm stucked =X i can't acces the web.
The steps i followed are:
1) I disabled the DHCP on the inside vlan and set the ip to 192.168.0.250
2) I disapbled the DHCP on the outside vlan and set the ip 89.201.240.176
3) I set the default gatway of the firewall with the command :
route outside 0.0.0.0 0.0.0.0 89.201.240.1 1
4) After spamming thousend thread & guides around the web i also checked the "dns rewrite" option for the nat rule.
At this point my config is:
ASA Version 8.0(3)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.250 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 89.201.240.176 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
access-list acl_icmp extended permit icmp any any
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
asdm image disk0:/asdm-603.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 dns
access-group acl_icmp in interface outside
timeout xlate 3:00:00
http server enable
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
no crypto isakmp nat-traversal
telnet timeout 5
ssh 192.168.0.0 255.255.255.0 inside
ssh timeout 60
ssh version 2
console timeout 0
threat-detection basic-threat
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
prompt hostname context
Cryptochecksum:9638054e33e69e33d971d5493df66e69
: end
Now the inside vlan is working and i can ping the firewall, i tryed ping the ip of google and it works, but i can't acces the web typing the URL on the web browser.
What do i have to do, what am i missing ? :oops:
16 years 9 months ago #26604 by sp1k3tou
What interface is your computer connected to on the ASA and what are the network settings you put on the computer?
16 years 9 months ago #26608 by buLLs
i am connected to the inside interface.
IP 192.168.0.5
NETMASK 255.255.255.0
GATEWAY 192.168.0.250
DNS 192.168.0.250
