Topology based question
16 years 10 months ago #26442
by kogula14
Topology based question was created by kogula14
Im taking ccna exam tommorow. But i have one doubt in question. Please look the question that i uploaded in this link:-
www.savefile.com/files/1592129
Below is the selection:-
A: Gateway_Router is configured to receive only RIPv1 updates.
B: Gateway_Router is configured to only receive RIPv2 updates.
C: Branch_Router2 is configured to send both RIPv1 and RIPv2 updates.
Branch_Router1 is configured to only send RIPv1 updates.
By the way,, the answer is (D). I just want to know the explanation for this answer.
Please anyone help me. Thanks
16 years 10 months ago #26444
by Chojin
Replied by Chojin on topic Re: Topology based question
I can't see your picture, but probably they want you to know the difference between RIP v1 and RIP v2.
One of the most significant differences is that RIP v2 supports VLSM. In other words RIP v2 also sends a subnet mask within its updates.
If you use RIP v1 you cannot use VLSM (CIDR), so you can only use classfull adresses.
Hope this is the answer u'r looking for
16 years 10 months ago #26445
by kogula14
Replied by kogula14 on topic Re: Topology based question
just go straight to the link and u need to download the file.
The download button nearly bottom of that page.
16 years 10 months ago #26456
by Chojin
As I said, see my answer in previous post.
Before making these questions and study your exam, it is much better to first understand what you are studying..
This is nothing more then knowing the difference between RIP 1/2
16 years 10 months ago #26494
Replied by S0lo on topic Re: Topology based question
If I'm not mistaken, A is wrong because the Gatway_Router is already showing classless routes (with a mask of /27). These masks can not be sent using RIP v1. B and C are wrong because there would be no DISPARITY in this case. D is correct because when Branch_Router1 is configured to only send RIP v1. It would not send the /27 masks with the routing updates. So the Gatway_Router will think it is classfull and set it to /24, which makes both routes appear as one 208.149.23.0/24
Hope that helps.
Hope that helps.
