Router connection problem
16 years 10 months ago #26285 by kogula14
I have a problem regarding routers. Below is my diagram
File Attachment:
I have 3 routers. My base network is 192.168.1.0 and im using this network to subnet into VLSM and i already created 3 LANs. [LAN 1, LAN 2, LAN 3]
Is it the routers connection must use same subnet or can be different?? I couldn't ping host from router 0 to host in router 2. But i can ping host from router 0 to host router 1.
When i ping it shows "destination host unreachable"
What could it be the issue? I confident that i assign correct IP.
Is it the routers connection must be under same subnets or can be diffrerent?
16 years 10 months ago #26286 by S0lo
Replied by S0lo on topic Re: Router connection problem
The image is not so clear. If you could post your packet tracer .pkt file it would be much easier to look into it.
16 years 10 months ago #26287 by kogula14
Hi, finally i can ping to all hosts from any LAN!!
Below is my diagram. However i have one doubt. Why I cannot use /30 subnets for all my router serial connections??
[I mean only for router serial conn part]
That's the problem that make me unable to connect to all host. The problem have been solved by changed to /29 subnets for all router serial connections. Why is like that?
www.savefile.com/files/1571362
16 years 10 months ago #26290 by S0lo
When I set the masks to /30 it works!!. From which to which were you pinging?
fixed file is here: www.downloadtaxi.com/d/1211718283
16 years 10 months ago #26291 by kogula14
Hi, First of all thank u very very much for your kind help!!!
Well, my previous configuration as below:
Router 0
s0/0 192.168.1.81/30
s0/1 192.168.1.86/30
Router 1
s0/0 192.168.1.82/30
s0/1 192.168.1.89/30
Router 2
s0/0 192.168.1.90/30
s0/1 192.168.1.85/30
**The serial connection between Router 0 [s0/0] and
Router 1[s0/0] works fine and can ping with that LAN networks.
**But other connection wont works for me.
Can u help me to clarify this?
Thanks.
16 years 10 months ago #26293 by S0lo
Router 2 configuration is flipped. It should be like this:
Router 2
s0/1 192.168.1.90/30
s0/0 192.168.1.85/30
