Cisco ASA 5505 Port Forwarding
17 years 3 days ago #25753 by eldersoul
I think I am losing my mind. I have followed every discussion I could find and as best as I can tell, things are set up as they should be. I simply need to forward port 21. My running config is as follows. Please help!
: Saved
ASA Version 7.2(3)
hostname ciscoasa
enable password lCrzpddxiv3Ah07a encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.3 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address ***.***.***.*** 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
access-list inside_nat0_outbound extended permit ip host 192.168.1.23 ***.***.***.*** 255.255.255.128
access-list outside_1_cryptomap extended permit ip host 192.168.1.23 ***.***.***.*** 255.255.255.128
access-list outside_cryptomap_1 extended permit ip host 192.168.1.23 ***.***.***.*** 255.255.255.128
access-list outside_access_in extended permit tcp any host 192.168.1.122 eq ftp
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
no failover
monitor-interface outside
monitor-interface inside
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
static (inside,outside) tcp interface ftp 172.16.1.214 ftp netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 ***.***.***.*** 1
timeout xlate 3:00:00
http server enable
no snmp-server location
no snmp-server contact
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 199.227.180.130
crypto map outside_map 1 set transform-set ESP-3DES-MD5
crypto map inside_map 1 match address outside_cryptomap_1
crypto map inside_map 1 set peer 199.227.180.130
crypto map inside_map 1 set transform-set ESP-3DES-MD5
crypto map inside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.4-192.168.1.254 inside
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
tunnel-group ***.***.***.*** type ipsec-l2l
tunnel-group ***.***.***.*** ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:3e76f42978e261ae63ef5749eacb3a4d
: end
17 years 3 days ago #25758 by Elohim
What are you trying to do?
: Saved
ASA Version 7.2(3)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
arp timeout 14400
http server enable
encryption 3des
hash md5
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
pre-shared-key *
: end
16 years 11 months ago #26050 by caelwind
You need to add the following line,
access-list outside_access_in extended permit tcp any interface outside eq ftp
Also is 172.16.1.214 you internal FTP server? Shouldnt it be?
static (inside,outside) tcp interface ftp 192.168.1.122 ftp netmask 255.255.255.255
