No/connection between dmz & internal. conf included
17 years 1 month ago #25439
by razmar
No/connection between dmz & internal. conf included was created by razmar
Hi guys!
I have a DMZ with webservers who need to connect to a SQL server (port 1433) on the internal network.
I tried with static routes and didnt connect.. What i'm doing wrong?
I receive a message:
" portmap translation creation failed for tcp 1433" from webserver (dmz) to sql server on the internal network.
I'm a rookie with little knowledge with ASA firewalls. So if theres is a standard configuration or a template to connect:
Outside ----> DMZ (webservers)
> SQl Servers (Data)(Internal Network
This is the configuration:
Result of the command: "show running-config"
: Saved
ASA Version 8.0(3)
hostname
domain-name ##
enable password ##### encrypted
names
name 192.168.1.11 PRH05WEB
name 76.76.194.163 Public_APP_Server
name 76.76.194.162 Public_WWW
name 192.168.1.14 PRH02APP
name 131.15.2.55 SQL-CLUS-IP
name 131.15.2.53 SQL-Node1
name 131.15.2.41 SQL-Node2
name 131.15.2.42 Prh03sql
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address ####### 255.255.255.248
interface GigabitEthernet0/1
nameif inside
security-level 90
ip address 131.15.2.254 255.255.0.0
interface GigabitEthernet0/2
nameif dmz
security-level 10
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 10.0.0.1 255.255.255.0
passwd ###encrypted
ftp mode passive
dns server-group DefaultDNS
domain-name AFVPR.local
object-group service WWW_SERVICES
description HTTP and HTTPS
service-object tcp eq www
service-object tcp eq https
object-group service mssql tcp
description Microsoft SQL
port-object eq 1433
object-group network DM_INLINE_NETWORK_1
network-object host PRH05WEB
network-object host PRH02APP
object-group network DM_INLINE_NETWORK_2
object-group network DM_INLINE_NETWORK_3
object-group network DM_INLINE_NETWORK_4
object-group service DM_INLINE_TCP_3 tcp
port-object eq 1433
port-object eq 1434
object-group network SQL-Cluster-servers
network-object host SQL-Node2
network-object host Prh03sql
network-object host SQL-Node1
network-object host SQL-CLUS-IP
access-list outside_access_in extended permit object-group WWW_SERVICES any host Public_WWW
access-list outside_access_in extended permit object-group WWW_SERVICES any host Public_APP_Server
access-list dmz_access_in extended permit tcp object-group DM_INLINE_NETWORK_1 range 1 65535 host SQL-CLUS-IP eq 445
access-list dmz_access_in extended permit tcp object-group DM_INLINE_NETWORK_2 range 1 65535 host SQL-CLUS-IP object-group DM_INLINE_TCP_3
access-list dmz_access_in extended permit tcp object-group DM_INLINE_NETWORK_3 range 1 65535 host SQL-CLUS-IP eq netbios-ssn
access-list dmz_access_in extended permit icmp object-group DM_INLINE_NETWORK_4 host SQL-CLUS-IP
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu management 1500
no failover
asdm image disk0:/asdm-611.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 101 interface
global (outside) 2 Public_APP_Server netmask 255.0.0.0
global (outside) 1 Public_WWW netmask 255.0.0.0
global (dmz) 200 192.168.1.2-192.168.1.254 netmask 255.255.255.0
nat (inside) 101 131.15.0.0 255.255.0.0
nat (dmz) 1 PRH05WEB 255.255.255.255
nat (dmz) 2 PRH02APP 255.255.255.255
nat (management) 101 10.0.0.0 255.255.255.0
static (dmz,outside) tcp Public_WWW www PRH05WEB www netmask 255.255.255.255
static (dmz,outside) tcp Public_APP_Server www PRH02APP www netmask 255.255.255.255
static (dmz,outside) tcp Public_WWW https PRH05WEB https netmask 255.255.255.255
static (dmz,outside) tcp Public_APP_Server https PRH02APP https netmask 255.255.255.255
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 #######1
timeout xlate 3:00:00
http server enable
http 10.0.0.2 255.255.255.255 management
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics
username admin password f3UhLvUj1QsXsuK7 encrypted privilege 15
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
prompt hostname context
Cryptochecksum:31624e23da8af2f6668400770becf59a
: end
: Saved
ASA Version 8.0(3)
hostname
domain-name ##
names
nameif outside
security-level 0
nameif inside
security-level 90
nameif dmz
security-level 10
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
passwd ###encrypted
ftp mode passive
port-object eq 1433
port-object eq 1433
port-object eq 1434
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu management 1500
no failover
arp timeout 14400
nat-control
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
: end
17 years 1 month ago #25449
by Sheikh
Replied by Sheikh on topic Re: No/connection between dmz & internal. conf included
you need a static & access list both to define the intersted traffic coming from WEB DMZ to INSIDE,
may be it will help you,
static (inside,webservices) DB_MappedIP DB netmask 255.255.255.255 0 0
access-list name permit tcp host Webserver_NATed host DBSRV eq 1433
always remember if u r coming from lower security level to higher security then u need a translation & then access[/u]
17 years 1 month ago #25454
by razmar
Replied by razmar on topic Re: No/connection between dmz & internal. conf included
Can I use this:
static (inside,dmz) 131.15.2.55 131.15.2.55 netmask 255.255.255.255
17 years 1 month ago #25455
by razmar
Can you helpme with this?
Config For check:
hostname #####
domain-name #####
names
name 192.168.1.22 WWW_Load_Balanced description Clustered or Managed IP for WWW
nameif outside
security-level 0
ip address 76.76.194.164 255.255.255.248
nameif inside
security-level 100
ip address 131.15.2.253 255.255.0.0
nameif dmz
security-level 50
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
passwd #######encrypted
ftp mode passive
domain-name ####.local
description Microsoft SQL Port
port-object eq 1433
object-group network Public_Web_Servers
network-object host WWW_Load_Balanced
access-list inside_access_in extended permit tcp object-group Public_Web_Servers object-group SQL-Cluster-servers object-group mssql
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu management 1500
no failover
arp timeout 14400
nat-control
>Correct???*****************
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 #########1
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
Cryptochecksum:5a2ba21a2fad22600e1cd96da20d3109
: end
Config For check:
hostname #####
domain-name #####
names
nameif outside
security-level 0
nameif inside
security-level 100
nameif dmz
security-level 50
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
ftp mode passive
port-object eq 1433
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu management 1500
no failover
arp timeout 14400
nat-control
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
: end
