Help me to decide
- noorfaizal
21 years 11 months ago #252
by noorfaizal
Help me to decide was created by noorfaizal
Hi there,
I'm planning to setup a multiplayer gaming center. It will have at least 30pcs. So my question is...
Shold i use 2 stackable 16-ports switches, or just 2 non-stackable 16-ports switches and connect them via cascading just to cater a very busy multiplayer gaming environment???
Thanx in advance.
-ryder0707
Thanx in advance.
-ryder0707
21 years 11 months ago #253
Replied by Chris on topic Help me to decide
Ryder,
If you choose to use 2 stackable 16 port switches, it would be like having a 32 port switch since your connecting one backbone of the switch to the other.
In practical terms though you most probably not be able to notice any difference in performance.
If the cost isnt much of an issue, then go for the stackable option.
