2511 setup issue
17 years 4 months ago #24067 by chchristie
2511 setup issue was created by chchristie
Good day, I have this 2511 i want to use for a access server but when i boot it and i enter the user mode of exec mode
it keeps on telling me it is loading a config file and timing out. I am a new comer to this and i want to setup my ccna lab at home so any assistance will be greatly appreciated. I have added an example below.
Cisco Internetwork Operating System Software
IOS (tm) 3000 Software (IGS-I-L), Version 10.3(18), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1997 by cisco Systems, Inc.
Compiled Tue 01-Apr-97 19:39 by jaturner
Image text-base: 0x0301B830, data-base: 0x00001000
cisco 2511 (68030) processor (revision D) with 8192K/2048K bytes of memory.
Processor board serial number 02313368
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
1 Ethernet/IEEE 802.3 interface.
2 Serial network interfaces.
16 terminal lines.
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
Loading network-confg ... [timed out]
Loading cisconet.cfg ... [timed out]
Loading buddy-confg ... [timed out]
17 years 4 months ago #24068 by Elohim
Replied by Elohim on topic Re: 2511 setup issue
The config is probably set to load from a tftp server. Go to rommon mode, change the configuration register (like you would for a password recovery), and the start-config.
Bridging software.
16 terminal lines.
17 years 4 months ago #24094 by jtartist
Replied by jtartist on topic Re: 2511 setup issue
I'm still learning here and I may be wrong, but I think the config-register command is used to tell the router where to look for the IOS immage, not the configuration file. Please correct me if I am.
I did some extra reading on this and I found this link here that may be helpful to you with this problem:
www.cisco.com/en/US/docs/ios/12_1/config...d2002.html#wp1019218
Looks like the "no service config" command may resolve this issue.
17 years 4 months ago #24100 by chchristie
Replied by chchristie on topic Re: 2511 setup issue
hi,
:D Thank you very much for responding to my question. that no service config command when used from after config t worked like a charm. It has been booting normally since then. Can one 2500 image be used on another 2500?
thanks
17 years 4 months ago #24228 by viper75
Replied by viper75 on topic Re: 2511 setup issue
Yep, you can use the same image as long as the routers are the same.
