IOS Problem
17 years 9 months ago #22427
by be30013
IOS Problem was created by be30013
Hey all-
Need your help on this please:
Have a 2924C-XL-A switch that I've blown out the IOS in error (typod the wrong delete) and I've tried using xmodem at all baud rates to restore the IOS. Syntax is:
copy xmodem: flash:image_name
I'm getting an I/O error after about 10 seconds into the copy. Any ideas how to get the IOS from the pc into the switch now?
Thanks in advance!
Thanks in advance!
17 years 9 months ago #22429
by be30013
Replied by be30013 on topic Re: IOS Problem
never mind...multiple part fix..I'll post in detail this weekend in case anyone else gets as stupid as me
17 years 9 months ago #22432
by yadav
hi
click on the below link u ll get the step by step instructions..........
www.cisco.com/en/US/products/hw/routers/...7e026.html#wp1042467
17 years 9 months ago #22434
by be30013
All kinds of wrong for this link...2600...not the problem I'm having..still.
Current issue:
'magic number mismatch' mayhem
Trying to load 12.0 CMS onto a WS-C2924C-XL-A...can get the IOS TO the switch, just can't boot it due to the magic # problem...I've tried different baud rates to cure the problem, though none work. I've loaded a different version of IOS and find the same thing. I was going to try to do a split load for IOS, then the Html counter part, but then can't figure out how to strip the html from the .tar files and there in lies the problem.
End result? I was CMS on 12.0 on my switch
Thoughts?!
Current issue:
Thoughts?!
17 years 9 months ago #22436
by be30013
Problem solved, though apparently it's not suppose to work.
I'm using 3 WS-C2924C-XL-A switches with 12.0(5)IOS with CMS on a 4/4 system.
The fix for me was to use ARCHIVE as opposed to loading the .tar file direct with #tar /x tftp..........................etc.
If anyone was curious~
- sanjudaveu
17 years 7 months ago #23260
by sanjudaveu
Replied by sanjudaveu on topic Re: IOS Problem
Hi Buddy,
try to upload IOS from TFTP server...
