WAKE ON LAN
17 years 10 months ago #22175
by sidekick
WAKE ON LAN was created by sidekick
I want to set up a wake on LAN in a DOMAIN with 80 workstations.I have an active directory environment running 2000 advanced server as DHCP server.How can I achieve this and what software can I use?
Please assist.
Please assist.
17 years 10 months ago #22177
by DaLight
Replied by DaLight on topic Re: WAKE ON LAN
Check out this
thread
17 years 10 months ago #22178
Replied by TheBishop on topic Wake On LAN
The most important thing here is to make sure your workstations can support Wake On LAN. This depends on the network cards used and on the BIOS. The best way is to do some tests using just one workstation. Once you've got that working it is easy enough to roll it out to the whole population using a script. As to software, again it depends on your LAN cards really. Do a google search for Wake On LAN Software and download a few - most are free. Then try them to find one that works reliably with your hardware. Try the stuff at
www.depicus.com
for starters - you get a couple of GUI apps for easy testing or ad-hoc working and command-line equivalents for easy scripting. They all work fine on my network.
Once you get under way feel free to post if you need more help
