Cisco Switches for CCNP lab
19 years 3 months ago #22126
by toddwoo
Cisco Switches for CCNP lab was created by toddwoo
Hello again all.
I've managed to get the routers I need for my CCNP and beyond lab, but I can't seem to find the switches I need..
So again I ask for you help in narrowing down what to look for.
1900 series seem to be too old to really be usefull, except maybe just 1 to have.
2900 series look good.. but ebay is not spitting out what I need.... same thing with the 500 express.
Is there some other switch I should be looking at?
the 1500 series micro switches any good?
Any help would be appreciated.
19 years 3 months ago #22138
by d_jabsd
Replied by d_jabsd on topic Re: Cisco Switches for CCNP lab
The micro switch will work for connecting devices, but won't do you much good as a device to learn with. It doesn't have enough functionality. Same goes for the 1900s... ok for basic connectivity, useless as a learning tool
Look for a couple 2924XLs or 2950s. Others to consider if you have extra cash would 3550s, 3560s, or 3750s, but they are quite expensive.
- skepticals
- Elite Member
19 years 3 months ago #22144
by skepticals
Replied by skepticals on topic Re: Cisco Switches for CCNP lab
I purchased several switches off of ebay. I would suggest the 2950s. I also found two 3620s (I think). I only went with the 3600 series because I got them cheaper than I found the 2950s. You should be able to find them for under $200. I think I purchased most of mine for $125-$200.
I would avoid the 1990s; they are junk. I believe they use the old CAT OS.
