Remote Desktop Can not see Printer
17 years 11 months ago #21713
by chandak76
Remote Desktop Can not see Printer was created by chandak76
I use RD (windows xp) to connet to my head office ( windows server 2003) from a branch office and every thing seems to work fine, my problem is that I can not see my default printer but can see one other printer on the network,I've tried to install the printer with no success.I've enabled windows printer mapping and LPT printer mapping with no success.The branch office in on a 192.x.x.x and the printer is shared through standard tpc/ip with a statin address, my head office is on a 172.x.x.x . Is there anything I can do to try and get this printer to work.Printer model is minolta Di250.
Thx
Thx
17 years 11 months ago #21714
by chandak76
Replied by chandak76 on topic Re: Remote Desktop Can not see Printer
Sorry I forgot to give the error message I get "Unable to install printer.Windows cannot install this printer until your system administrator first installs a new driver on your computer without the assistance of your system administrator, run the print troubleshooter and select the option that contains this message:
"The current printer driver is not compatible with a policy enabled on your computer that blocks windows nt 4.0 or windows 2000 kernel-mode drivers""
[/img]
[/img]
- skepticals
- Elite Member
17 years 10 months ago #21766
by skepticals
Replied by skepticals on topic Need driver
When you say you installed the printer, do you mean you installed the driver? What happened after doing so?
17 years 9 months ago #22244
by junaidjan
Junaid
Replied by junaidjan on topic Re: Remote Desktop Can not see Printer
Hi!!
In Remote Connection Dialog Box Click on "Options Tab" and then Click on "Local Resources" after that at the bottom check Printer Option and then see whether it will work or not!!
Junaid
- muriloninja
17 years 7 months ago #22929
by muriloninja
First thing I would have checked!
If not, he will need to install the driver on his machine. Will need admin rights.
Replied by muriloninja on topic Re: Remote Desktop Can not see Printer
Hi!!
