HELP!!!
- MForlingieri
17 years 11 months ago #21476
by MForlingieri
HELP!!! was created by MForlingieri
ok, to make this short.....
i have A PC and need to connect it to a Cisco Router(router A) Via Ethernet, then i need to another Cisco Router(router
via Ethernet. Router B is my main router. i can ping from PC to router A but i can not ping from router a to router b and from PC all the way to router B
17 years 11 months ago #21495
by anti-hack
Replied by anti-hack on topic Re: HELP!!!
hi,
if possible could you please draw a little diagram .. just lines and names to display the toplogy. Normally you have to place routes in the router that is in between the PC and the Router.
But for accurate response it is best to get a visual or a clearer description.
thanx
thanx
17 years 11 months ago #21496
by d_jabsd
Please post more information. IPs/Subnets, a diagram, the router configs, etc.
There is no way to tell whats wrong with the information you have given.
Replied by d_jabsd on topic Re: HELP!!!
i have A PC and need to connect it to a Cisco Router(router A) Via Ethernet, then i need to another Cisco Router(routervia Ethernet. Router B is my main router. i can ping from PC to router A but i can not ping from router a to router b and from PC all the way to router B
