dhcp vs static
18 years 2 weeks ago #20658 by ashine
dhcp vs static was created by ashine
hey all..
as a part of our final yr proj,v r proposin a revamped design of our coll LAN(700 odd PCs and 7 departments)..currently all da IPs are manually assigned...jus wanted to hw significant a differnece wuld implemnting DHCP mk(since v r propsoin a VLAN design)...does it cause additonal overload or is easier to manage..? also if u guys culd suggest sum gud links for dhco wuld b of gr8 help!!
18 years 2 weeks ago #20669 by smitherton
Replied by smitherton on topic Re: dhcp vs static
My first suggestion would be to brush up up on your professional writing skills. Secondly, I would shoot myself if I was the admin of a network that had 700 hosts all of which are using a static addressing scheme. As far as implementing a DHCP server, Windows Server will do just fine, or you could use DHCP on your router, (depending on model)
18 years 2 weeks ago #20672 by KiLLaBeE
Replied by KiLLaBeE on topic Re: dhcp vs static
smitherton,
Is there an advantage to having a dedicated Windows Server 2003 running as a DHCP server V.S. having a router to provide the DHCP service?
K
18 years 2 weeks ago #20674 by smitherton
I do not consider myself to be a professor in windows 2003, but I could see advantages in using Windows 2003 for DHCP for several reasons:
1)Delegate control through active directory
2)Good integration with Windows DNS. When DHCP updates an address it updates records in the DNS database.
3)A nice GUI with good reporting and stats
4)Detects unauthorized DHCP servers in network.
I am not saying that windows is the only software that will do these things, but they do make it pretty easy.
18 years 2 weeks ago #20678 by Smurf
Replied by Smurf on topic Re: dhcp vs static
Isn't that providing its a Windows DHCP services that is on the network ?
18 years 2 weeks ago #20693 by smitherton
I am not sure, I know that a DHCP server will send a DHCPINFORM via multicast is it then possible to restrict what hosts are in the multicast group?
