Network Design Help
18 years 1 month ago #20425
by r4v3n
Network Design Help was created by r4v3n
I'm trying to change the setup at work from a workgroup to a domain environment. I have a win2003 server (dual NIC cards), which i plan to make the Domain Controller.
My network setup at the moment is very simple with 8 workstations, 2 wireless users and 1 printer.
Here is a diagram of the existing network :
img459.imageshack.us/img459/2843/networkdj4.jpg
Could someone please tell me how i need to change this existing setup, to sucessfully migrate to a DC environment ?
18 years 1 month ago #20428
Replied by S0lo on topic Re: Network Design Help
If you type "dcpromo" on a command prompt on your server, the wizard for converting to DC will start. But, I really recommend that you have a good understanding of the issues involved in DCs and Active Directory before you proceed.
17 years 10 months ago #22199
by junaidjan
Junaid
Replied by junaidjan on topic Network Design
Hi!!!
As i have gone thru the ntwork diagram.. Everything is perfect.. Just run DCPROMO as suggested by solo.. Be a bit careful while dealing with DNS in DCPROMO wizard.. Let it install DNS... There is no need to install DHCP as it is on Router.. The DNS which is on DC will act as internal DNS for users and the DNS on Router will act as External... Now you can create users on DC(Active Directory) and u r done!!!!
Junaid
17 years 10 months ago #22209
by anti-hack
Replied by anti-hack on topic Re: Network Design Help
Run "dcpromo.exe", yes. But you have to define a scope in your DHCP for the users, as the Domain Controller and the DNS require a static IP address. The range that you exclude from the DHCP will help you in the future for you Email Server and Proxy Server etc. if you wanna add , if you already don't have them.
The rest should not be a problem.
17 years 10 months ago #22211
by Smurf
Replied by Smurf on topic Re: Network Design Help
I would personally set the DNS Server to forward all external requests to your ISP's DNS Server. The clients will only need to set their primary dns to the Windows DNS Server.
