Connecting multiple patch panels
18 years 1 month ago #20010 by sidekick
I want to connect three patch panels and three switches using cat5 utp with TIA/EIA 568B standards.How can I interconnect this devices?Please help on how I should terminate the cables.
18 years 1 month ago #20011 by Rockape
Hi Sidekick
Interesting question, and I'll try and answer as best I can.
Ok
For your patch panels they can be connected to a switch via fiber leads, or you can connect via cat5 direct to the switch.
For the switches, if you are connecting them together, normally you would have a "stacking Lead" to connect them together.
Sorry the answer is a bit vague, but hopefully it will point you in the right direction.
Rockape
18 years 1 month ago #20032 by TheBishop
Sidekick, are you wondering about whether to use straight through or crossed-over connections between the switches?
18 years 1 month ago #20044 by sidekick
Hi bishop,I wanna use straight through connection will that work?And how can I intreconnect the switches?
